Radio Display Lights- Off then On
Old Dec 14, 2020 | 06:22 PM
bobdisp's Avatar
5 Year Member
bobdisp is infamous around these parts
2005 DB9. I get in Sunday morning for the 3 hour drive home. All good except the display on the radio. Everything worked except the lighted display. No outside temp, fan speed, temp setting, nothing. All other dash lights worked. I stopped and fueled up about 100 miles out. When I fired her back up, everything worked. Gremlins?? Who else has seen this?
Old Dec 17, 2020 | 09:46 AM
sliderule01's Avatar
sliderule01 is infamous around these parts
Sounds like an intermittent ground
Old Dec 17, 2020 | 06:23 PM
bobdisp's Avatar
5 Year Member
I give up 01. what is a IG?
Old Dec 17, 2020 | 06:45 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Potentially a loose wire or loose/dirty connection somewhere under the waterfall and vibration is causing a ground wire connection to be sporadic. There are some good videos on waterfall removals...just be careful. Make sure your power is OFF when you check the connections as not to cause a short or blow a fuse.
Old Dec 18, 2020 | 01:13 PM
bobdisp's Avatar
5 Year Member
Thanks 01 & 07......
bobdisp
Dec 31, 2018 04:05 PM
K9COP
Jan 29, 2016 05:46 PM
steve36
Aug 21, 2014 05:26 PM
PrecisionPorsch
Oct 26, 2012 11:52 AM
