Vantage - Getting the battery cleats off
Old Feb 6, 2021 | 09:06 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
I'm replacing the battery and I'm at the stage where I need to slide the cleats off the feet of the battery. I don't want to damage the trim panel at the side of the car that is keeping the cleats from sliding off. I can't find instructions on removing the entire panel or a good way of moving it out of the way to make room for the cleats. What's everyone's method?
Old Feb 6, 2021 | 09:38 PM
Lefach's Avatar
Lefach is infamous around these parts
I have never done this so take it with a grain of salt, but I thought I have read that people actually trim the trim panel to make space to slide it, I will try and do a search in the morning when I have more time, or hopefully someone with actual knowledge will chime in.
Old Feb 7, 2021 | 05:40 AM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
The first tools that go into the cart when I work on my DB9 are an area flood light, pencil beam fliash light, and the ever trust mirror on a stick and magnet on a stick. I have found the magnet on a stick to be really useful for moving battery feet out of the way..
Old Feb 7, 2021 | 05:56 AM
embdenb's Avatar
You want to trim a small portion of the fiberboard. It’s all hidden behind the trim , I also cut the battery clamps to make them smaller so that subsequent battery replacement would be easier,
Sent you a PM with a website url. The website details the process. Hope it helps
Old Feb 7, 2021 | 06:29 AM
J doubleU's Avatar
You don't need to trim or cut anything, if you gently pull the lower panel towards the center of the car and forward. It allows you enough room to slide them out downwards. Its worth a try before hacking into the edge of the panel.
Old Feb 7, 2021 | 09:45 AM
blue2000s's Avatar
That's my concern. You have to pull pretty hard and I don't want to break any clips or screw posts that hold the panel to the car. I'm really hoping that the side panel pulls off the car after removing the one exposed screw at the back of the car exposed when removing the parcel shelf but I don't want to start yanking on the panel if there are other screws that I don't know about.
Old Feb 7, 2021 | 10:36 AM
J doubleU's Avatar
You only move the very bottom edge 1"-2" at most, just enough to slide the peice by. Just flex it a bit, it will not damage anything.
Old Feb 7, 2021 | 12:14 PM
blue2000s's Avatar
Thanks. I got it doing it as you describe. Having broken many panels by pulling on them, I'm always leery about just pulling.
Old Feb 7, 2021 | 03:06 PM
61mga's Avatar
61mga is infamous around these parts
I've done it without breaking or trimming anything. It's not for the timid....and takes some effort. I think I removed the sill plate, but not sure that it was of any help though.
Old Feb 9, 2021 | 08:28 AM
kdm's Avatar
kdm
5 Year Member
kdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of light
I cut a small section out of the trim. As other have said it is hidden once you get everything back together and the next time a battery swap is needed (which should be a long time) , the job will be easier. I replaced the battery in ours with an AGM which weighed about the same as the original, so careful how you lift so you don't strain your back.
AMBT7
May 3, 2021 02:39 PM
DetomasoGTS74
Jun 29, 2020 03:11 AM
aacstyle
Apr 28, 2019 08:02 PM
minming
Dec 21, 2017 10:29 AM
