Vantage hand brake issue
Old Jul 6, 2021 | 04:46 PM
shahriar35's Avatar
shahriar35 is infamous around these parts
Hi all,
I'm currently working on a 09 Vantage. It is from an auction where it had right side damage, so it affected the right side front and rear suspension.
Finally got everything bolted up and on the ground and ready for a test drive. However, the brake light remains on. I noticed one of the levers on the e-brake is not touching the switch that disables the light. So if I reach behind the e-brake and help the lever down to touch the switch, the the light goes away. I'm wondering if the lever is actually sticking or is there another issue?
I'm going to attempt again today to see what happens. But any insight is appreciated.
Thanks!
Old Jul 6, 2021 | 07:48 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Originally Posted by shahriar35
Hi all,
Thanks!
similar problem on my db9. I cut a small piece of plastic tubing and slipped it over the nub that makes contact. Effectively increased it in diameter. Light goes off now when I drop the handle.
Old Jul 7, 2021 | 09:08 AM
RDroz's Avatar
RDroz is infamous around these parts
Same on my '07 V8 Vantage. I put a drop of epoxy on it and let it harden. It was enough to make contact.
Old Jul 12, 2021 | 04:23 PM
shahriar35's Avatar
Thanks guys! Thats not a bad idea about the epoxy and the plastic tube!
AMTas
Feb 13, 2021 06:13 AM
DonRW2007
Jun 24, 2020 04:11 AM
E30 Racer
Apr 13, 2020 07:50 PM
polutski
Oct 28, 2017 01:13 AM
SeattleBum
Cayenne 955/957
Jun 18, 2008 06:01 PM
