Passenger window and mirror not working. VV8
Old Aug 22, 2021 | 04:39 PM
geodavky's Avatar
geodavky is infamous around these parts
I haven’t checked the fuses yet because when I turn the ignition switch on I hear the mirror motor running, but the mirror does not move. The battery died recently and this began a few days after the recharge. Would it help to disconnect the battery for a few minutes?
Old Aug 22, 2021 | 09:05 PM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
I had this happen once, is your side repeater light also not working?
https://www.6speedonline.com/forums/...ml#post4825998
To fix it I opened up the passenger side floorboard fusebox, pulled both F82, F83 and inspected them... both didn't seem blown so I popped them back in, as I popped in the F82 Fuse for the passenger side door I heard the window move, and what do you know the problem was fixed... mirrors, repeaters, and windows all wound up working fine again...
Old Aug 23, 2021 | 05:01 AM
handyman2009's Avatar
Veteran: Canadian Forces
Yeah do exactly what Sonies said, the problem is when you plug the battery back the module didn't initialized properly so taking the fuse out and putting it back in will restart only that module which usually fix this issue
mmmmm
Oct 27, 2015 12:11 PM
eyeain
Nov 23, 2013 03:40 AM
drhenrock
Jan 23, 2010 08:48 AM
Craig
Aug 22, 2005 12:55 PM
