Antenna base replacement
Old Sep 14, 2021 | 08:24 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
I discovered that what appears to be a gasket under the antenna base on the roof is disintegrating...has anyone replaced this? It appears to be a part of the antenna base as a whole and is attached with a nut securing the coaxial cable in the recesses of the headliner...I hope I am mistaken.
Old Sep 17, 2021 | 07:16 AM
embdenb's Avatar
I don’t think you are mistaken. I believe the headliner has to come out to access the antenna base.
Old Feb 21, 2022 | 08:13 AM
Marmot's Avatar
5 Year Member
I seem to recall a thread regarding dropping the headliner, but I can't find after multiple searches. Has anyone done this? Is there a DIY? The rubber gasket on my antenna base has split and I don't want water getting into the car through the now more exposed aperture.
Juanna Knowtrooth
Cayenne Turbo
10
Jan 5, 2017 04:44 AM
Freeze
Aug 7, 2013 09:16 PM
brwiedman
Nov 16, 2012 09:58 AM
luvmyC4
Dec 18, 2006 02:57 PM
