Replacing Vanquish II Taillight
Old Sep 28, 2021 | 09:26 AM
silver86's Avatar
silver86 is infamous around these parts
Doesn't seem like it should be too complicated, but just checking to see if anyone has done the DIY replacement on one of these or has any tips. The layout does appear to be different in general from the Vantage/DB9 in that, it doesn't seem to be as easy to access the lights behind the carpet without undoing quite a few fasteners/screws.
Thanks in advance
Old Sep 28, 2021 | 06:23 PM
dpath's Avatar
5 Year Member
dpath is infamous around these parts
It’s fairly straightforward. After pulling back the carpet, you will gain access to about six M6 taillight cover screws which need to be removed. The taillight is held on to the car with this cover. Also note that there are a couple of taillight adjusting screws which control the depth of the taillight in relation to the bumper. Sorry to hear your ($4K) taillight needs to be replaced.
Old Sep 28, 2021 | 06:42 PM
silver86's Avatar
Thanks! There is a small carpet covered panel in the trunk right between both lights (I think held on by 6 screws), and I was curious if that needed to be removed for ease-of-access/before pulling back the carpet.
And, yes, that's exactly what it cost...though a few dealerships wanted a couple, to several thousand more just for the replacement.
Old Sep 28, 2021 | 07:04 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Hi Silver86, You might want to see the links in the FAQ section of this forum to help you accomplish the change out. There are 2 links that might be of interest. Good luck
Old Sep 28, 2021 | 07:31 PM
dpath's Avatar
5 Year Member
My recollection is that the center piece of carpeting does not need to be removed. Good luck.
goto35
Aug 3, 2015 05:33 AM
Christian
May 14, 2015 05:10 AM
Allen121
Oct 24, 2010 03:57 PM
blayne
Dec 1, 2009 03:56 PM
Jeff SD
Apr 21, 2007 05:16 PM
