V8 Vantage Downstream O2 Sensor Part #
Old May 22, 2023 | 10:56 AM
  #31
J doubleU's Avatar
Forgot to add also P0133 is a code for upstream sensor, so pre catalyst (green factory connector) RH side B1 S1 just to clear up the confusion.
JW
Old May 25, 2023 | 09:50 AM
  #32
tranceatlantic's Avatar
tranceatlantic is infamous around these parts
Hi Jay. Thanks for the info. Do you have a reference for whether P0133 is upstream or downstream? All my searches result in that it is downstream and thus after the cat. I was wondering if this is something specific to Aston, Volvo or Jags?
Old May 25, 2023 | 10:15 AM
  #33
J doubleU's Avatar
P0133 is the same on any vehicle, bank 1 sensor 1. Sensor 2 would be downstream. Some diagnostic procedures tell you to reference downstream sensor for comparison to upstream.
Old May 25, 2023 | 10:36 AM
  #34
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
Originally Posted by J doubleU
Bank 1 is on the RH side passengers, you really should replace them in pairs. Like headlamp bulbs and b()()bs.
Great advice, always replace both b()()bs at the same time.
I thought these were Lambda sensors? Just did my upstreams, bought them from bits since the exchange rate is so good and I had alot of credit. Bought a clean pair of headlights off ebay so did the door struts, side indicators, fead belt, and air filters while I had the airboxes out. No wonder there are so many broken airboxes trying to get those to expand over the flanges. Adjusted the emergency brake and called it for now. Next stop rotors, pads and tires. Still need to get the black eye fixed but try getting a light bucket.
Old Dec 17, 2023 | 07:02 PM
  #35
amv8ma's Avatar
amv8ma is infamous around these parts
For the Upstream sensors, I replaced the OEM ones with OZA816-EE1 and passed emissions in a breeze. I also tried the NTK 22009's and those tripped off the Check Engine Light immediately after installation.
Old Dec 18, 2023 | 04:11 AM
  #36
handyman2009's Avatar
Veteran: Canadian Forces
Good to know, what year is your car? and I was told that the Upstream and Downstream are the same just the cable is different lenght
Old Jun 18, 2024 | 05:01 PM
  #37
ragingfool35's Avatar
ragingfool35 is infamous around these parts
anyone know if these part #s are same for 2009+ 4.7?
Old Dec 14, 2024 | 03:08 PM
  #38
TonyN923's Avatar
TonyN923 is a jewel in the roughTonyN923 is a jewel in the roughTonyN923 is a jewel in the roughTonyN923 is a jewel in the rough
Just want to confirm
22106 for fronts
22009 for the rear.
I have a 09+ 4.7L if that makes a difference.
Can anyone please confirm
cadman
Jun 30, 2021 09:11 AM
Marmot
Mar 5, 2021 10:36 AM
dark1
Jun 20, 2019 10:08 AM
rolltide0323
May 9, 2019 07:14 AM
Doc Martin
Jan 5, 2016 05:00 PM
