2007 DB9 Volante gas cap
Is there a Ford, Volvo, Land Rover, Jaguar replacement for the DB9 gas cap? I have a P0442 code that came back after replacing the purge valve.
if db9 is the same as a vantage,i'm sure it would be. a Mazda 3 or 5 cap of the
same era will fit.although they are cheap plastic caps you can
put the innards into the factory cap if you wish
i have one on my car
Post #24 gives a Land Rover Part (LR053665) that apparently works for a Vantage...can't imagine that a DB9 would be different?
https://www.6speedonline.com/forums/...gas-cap-2.html
YMMV
YMMV
gtmule
May 6, 2021 07:42 PM
