DB9 air conditioner compressor
Old Nov 5, 2021 | 08:23 PM
Deanoroger's Avatar
Deanoroger is infamous around these parts
Hi all
Did a search for this but came up nil.
Is the air conditioner compressor in the 2009 DB9 common with something devoid of the Aston tax? Eg Ford, Jag? I have a horrible feeling I may be up for one soon.
Cheers Dean
Old Nov 14, 2021 | 09:54 AM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
Hi I have original AM AC compressor for DB9, I ended up not using its brand new I think i paid $ 900, i was going to list on eBay but have not yet
oh and its denso but i could not find any after market too
Old Nov 14, 2021 | 10:00 AM
ALSO CHECK IF its leaking green fluid than where is it leaking from, in my case it was leaking from a brass part (i think i posted about repair on forum) the brass part is called AC compressor pressor control valve, you can find it on eBay for about $ 28 , you can swap it very easily without removing AC compressor , empty the system (local AC shop can do it for like $ 35), just remove circle clip, pull the brass part out , put new one in (there are o rings and big one starts leaking, you could even find a ring then you can fix it in 1 dollars plus cost of refilling the AC system), refill the system
Old Nov 14, 2021 | 12:10 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Insert critique of china and stuff from there here --> <---, but this one works great in my DB9: https://www.aliexpress.com/item/32985979592.html
I use Nyloc Blue on all the o-rings, which I did buy from Scuderia because I didn't like the quality of what I could find locally.
I bought a Jag drier and tig welded the bracket from the AM drier on to it. Same drier, different mount, 1/10th the cost.
ATB
Larry
Old Nov 14, 2021 | 04:55 PM
Deanoroger's Avatar
Thanks very much for the reply guys.
Wildcat, I think the freight from US to West Australia may be prohibitive and I'm not sure I need a compressor yet. I did read somewhere about the Jag drier but don't have the know how or equipment to modify it to fit so have just ordered the AM part complete with AM tax (about 220 AUD)
Old Nov 17, 2021 | 10:31 PM
convexproblem's Avatar
convexproblem is infamous around these parts
It says Denso 5SA12C on that listing, I see supposedly remanufactured ones for 500 something bucks, which is a little better than the Ebay people asking 900.
I think all new cars use variable displacement compressors now, so the off-brand replicas might be the only ones left at some point. I am kind of curious if any variable displacement compressor will bolt up to the factory bracket with the correct pulley offset...
theging3r
Aug 1, 2022 11:18 AM
gtmule
May 6, 2021 07:42 PM
randyb
Jun 29, 2016 05:36 PM
zuman
Jun 18, 2016 11:53 AM
donahdi
Jun 28, 2010 04:33 PM
