V8 vantage spark plugs and coil change
Old Dec 23, 2021 | 08:11 PM
Psycho123's Avatar
Psycho123 is infamous around these parts
Hi all, just want to know other owners on how often do you change your plugs and coil for your v8 vantage. Do you actually follow the recommended timeline? Have anybody just change the plugs and not the coils?
Old Dec 24, 2021 | 05:19 AM
V8Vdrew's Avatar
5 Year Member
V8Vdrew is a jewel in the roughV8Vdrew is a jewel in the roughV8Vdrew is a jewel in the roughV8Vdrew is a jewel in the rough
Just recently did my spark plugs due to age, not mileage. I believe it was 7 years or 70k miles. The car only had 13k miles but is a 2013. Did not do the coil packs as upon inspection they were perfectly fine.
13:24 shows spark plug change
Old Dec 24, 2021 | 06:31 AM
61mga's Avatar
61mga is infamous around these parts
https://www.youtube.com/watch?v=OcosYvcnm2U&t=804s
those spark plug tips look to be ablated, which will increase the gap between them. good that they were replaced.
Old Dec 24, 2021 | 06:46 AM
V8Vdrew's Avatar
5 Year Member
and as far as changing the spark plugs and coil packs separately... it depends on difficultly the job it.
Yup, it was time for the plugs to go. The process is fairly simple until you get towards the back where it becomes a little difficult to maneuver, but hard at all. I would say the price is another factor as each coil pack is a little over 100 per.
Old Dec 24, 2021 | 06:57 AM
61mga's Avatar
BTW, that long and wide horizonal aluminum brace is easily removed. and i suspect that goes for the shorter one too..
Old Dec 24, 2021 | 08:16 AM
8Tech's Avatar
5 Year Member
8Tech is infamous around these parts
I wasn't aware the V8's had coil issues? I was under the impression it was only the V12's running the coils too hot that caused an issue.
Old Dec 26, 2021 | 05:41 AM
V8Vdrew's Avatar
5 Year Member
Yes, the braces are easily removable, however I dont remember them being that much of a pain to work around, it was more that brake reservoir. Still would have been easier to remove the brace though.
I dont think v8 have that issue. Just replaced due to maintenance cycle. V12 have that issue cause they run hot. Also a pain to replace as you have to take more things off to access them.
koruzou
Jan 27, 2022 02:06 PM
terminal_ac
Sep 26, 2019 03:02 PM
rolltide0323
Apr 15, 2019 07:38 PM
cshsia
Feb 3, 2019 12:09 PM
DetomasoGTS74
Jul 10, 2016 06:26 PM
