V12 Clutch Kit aka 4G43-11-11200
Hi,
Trying to figure out how to convert the mentioned kit above to a V8V.
Does anyone happen to know what are the part numbers of the items included in this kit ?
1) The twin plate clutch is the 228mm version that fits several different 12 Cylinder cars (Vantage V12 Non S, DB9 (2004-2012), DB V12, V12 Zagato). Does anyone know the part number ?
2) Is the slave cylinder used 4G43-7A564-AB (V8 Vantage, DBS V12, DB7 Vantage, DB9 (2004-2012) or AD23-7A564-AA (DBS V12, V12 Vantage S ?, V12 Zagato)
3) Regarding the spacer, would the OEM V8 part 6G33-209031-AB suffice,or would this one need to be modified to accommodate the kit ?
4) As per the flywheel, I am not interested in knowing because the one in the kit wouldn’t fit the V8, therefore a TTV racing (6.7kg) or a AKR racing (5.56kg) would be ordered.
5) Not too worried about the flywheel to crank bolts and the clutch to flywheel bolts, etc..that can be sorted out at a later stage.
Thanxs
Benson
Thanxs
Benson
Do you have one just laying around? I believe that's the same clutch pack used in the VAP V8 kit with the custom flywheel and spacer. I'd start there.
https://www.velocityap.com/product/a...-sportshift-2/
