Weird GPS failure
Old Aug 16, 2022 | 10:47 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
Weird GPS failure
I know, I know, the old GPS is garbage. That being said, it does function. Yesterday I turned mine on, mostly for keeping the time/speed/distance calculation accurate to get to an appointment 100 miles away. Anyway, weather was both raining, overcast, then sunny and clear, and it would not connect to the satellite constellation. I believe the map disc is fine, as it would show the location on the map for the destination, but could not identify where the car was located in order to perform the calculation. Any ideas or theories on what's going on here? I did not find any notice from the US gov. on GPS outages, but I suppose anything is possible. Thoughts?
Old Aug 26, 2022 | 06:15 AM
Marmot's Avatar
5 Year Member
Well, five days later the GPS started picking up the satellites again, and a day after that figured out the correct location of the car...I'm going to go with 'solar flares'...or something...
Old Aug 26, 2022 | 12:20 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
You raise a good question - how many channel GPS does the AM use? More the merrier and the more robust it's ability to geolocate.
Here's an interesting site and some comments on Geomagnetic activity (related to solar activity) and GPS: https://www.swpc.noaa.gov/impacts/sp...nd-gps-systems
We should all thank Roger Easton and Martin Votaw - the guys at the Naval Research Laboratory who patented and invented GPS. They lived long enough to see the commercial and civilian use of what they thought would only be used by US Naval forces at sea...
Old Aug 27, 2022 | 06:27 AM
Marmot's Avatar
5 Year Member
I used to live across the river from NRL and sail / row past it regularly on the Potomac in high school.
I believe the Aston / Volvo / Ford hobgoblin system uses 6 satellites when it is optimally functional. I had "other suspicions" about why civilian GPS wasn't working for a week, but I couldn't find any other complaints during the time period, so I'm chalking it up to space weather. I was in at least a dozen locations over the week attempting to connect, from moderately treed areas to very open parking lots, so I don't think it was overhead cover interfering. Weather was from overcast, to clear, to thunderstorms, too many variables to pin it on that. I suppose it could also be some sort of intermittent connection failure for the antenna but that doesn't explain why it would not load the previous map location etc. from the the main drive. Mysterious.
shumi_9
Aug 18, 2015 08:03 AM
gnat
Cayenne 958
Jul 12, 2013 06:31 PM
PorscheCrazy
Mar 25, 2013 06:27 PM
steph280
Cayenne 958
Jan 18, 2012 11:06 AM
hblocal
Cayenne 955/957
Apr 2, 2008 04:03 PM
