2019+ Vantage DIY Oil Change
Old Oct 12, 2022 | 06:06 PM
Stwsam's Avatar
Stwsam is infamous around these parts
Has any member performed an oil change on the new vantage. Plenty of info on 2016 and earlier online.
Old Oct 12, 2022 | 06:09 PM
volvodrummer's Avatar
volvodrummer
A member here or on PH just posted a thread about it the other day. Said it was a breeze.
Old Oct 12, 2022 | 06:15 PM
volvodrummer
Yup, PH thread here , by "Greasy Hands" on p.150.
here
Old Oct 12, 2022 | 06:35 PM
Stwsam's Avatar
So let me ask if anyone knows how to do it?? Greasy Hands said he did it and it was easy. Looking for basic directions.
Old Oct 12, 2022 | 08:58 PM
V12Vin's Avatar
V12Vin
Given it's a M177 engine, I am guessing this might help: https://mbworld.org/forums/c63-c63s-...2018-c63s.html
There are some schematics. Ask around mbworld. Friendly folks. I have a GT R with M178, close cousin of M177.
Last resort: sign up https://technicalhub.astonmartin.com/amtis/
Old Oct 13, 2022 | 08:01 AM
chadster's Avatar
chadster is infamous around these parts
Just did it yesterday. Jack up driver side front. T40 torx for drain plug. 24mm socket for filter. Remove 3 bolts behind the cutout of the oil pan to get to filter. 3 bolts remove a triangle shaped cover that protects oil filter. Filter # E155hd122
9 Liters of motul 8100 0w40. Take pictures to keep warranty clear.
Old Oct 13, 2022 | 08:05 AM
Stwsam's Avatar
Thank you!!!!My new hero!!! I now have the confidence to proceed!!1
Old Oct 13, 2022 | 08:19 AM
chadster's Avatar
You're welcome. Just be sure to use jack stands for safety.
Old Oct 13, 2022 | 08:26 AM
Stwsam's Avatar
For sure, not my first rodeo, just first time with this car and not a lot of online info on newer vantage. Plenty on my former 2015.
Thank you again!
Old Oct 13, 2022 | 08:27 AM
Semitone's Avatar
Semitone is infamous around these parts
I have a 2019 MY. There was no obstruction for me to access the oil filter, so no need to remove three bolts or any cover. I’ll have to go back and look to see if it was removed and not replaced in a previous oil change or perhaps the design was changed post 2019.
Old Oct 13, 2022 | 01:07 PM
chadster's Avatar
This is the triangular aluminum piece I removed to get to the filter housing. There were (3) 10mm bolts.
Old Oct 13, 2022 | 01:10 PM
chadster's Avatar
Old Oct 13, 2022 | 01:19 PM
khiroshima's Avatar
khiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond reputekhiroshima has a reputation beyond repute
Looks simple (as it should be), was resetting the trip computer straight forward too? KH
Old Oct 13, 2022 | 01:46 PM
Semitone's Avatar
I just crawled under the car out of curiosity. I think I see the triangle you are referring to but I was able to remove and replace the filter/ housing without removing it. Just need to angle it a bit.
Next time I get the car off the ground I’ll take a closer look.
Regarding resetting the oil reminder. I used a Mercedes OBD device the first time I changed it. Second time, I just used the steering wheel controls. There’s a video on YouTube where a guy resets his reminder on a DB11. Same process for Vantage.
Old Oct 13, 2022 | 01:58 PM
khiroshima's Avatar
Thank you, very cool and much appreciated-- KH
Shortpballer
Nov 21, 2024 09:49 AM
Golfpunks
Oct 13, 2022 01:31 PM
goto35
Jun 27, 2020 06:46 PM
viggen
Mar 16, 2019 09:24 AM
dicktahoe
Jul 23, 2013 09:23 AM
