DB9 Camshaft position sensor wiring
Old May 25, 2025 | 07:43 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
I don't know why there is a #7... I don't recall a sensor on the rear of the block.
Old May 25, 2025 | 07:47 PM
jbranco's Avatar
jbranco
No worries! Reason why i ask is because as I mentioned i changed spark plug/ coils and I thought maybe i knocked the connector at the back hence the P0340 about camshaft position sensor. As you indicated the actual position sensor is in the front (must be near the camshaft ). So at least it seems i didnt knock anything, just so happen when i start the camshaft position sensor decided to go
Other side rear view of no 7
Rear sensor of no7
Rear sensor of no7
Old May 27, 2025 | 06:46 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Originally Posted by EJ_Rapide
Is it triggering a CEL, or is it just stored in the memory?
Both. Does not affect engine performance though. Comes on the 2nd ignition cycle once cleared. I need to get my car inspected this month too .
Will have to jump through a few hoops to clear the code, drive long enough to clear it and then get it inspected. Mechanic thinks it's ECM related. Looking to buy a used ECM to test.
Old May 27, 2025 | 06:47 AM
5 Year Member
Originally Posted by jbranco
Do you mind sharing where the sensors for the camshaft are located? i have been trying to find a diagram that shows me where the connector/ sensors are to ensure they didn’t come unplug somehow while i was changing my spark plugs/ coils.
Do you need to remove the manifolds in order to replace the camshaft sensors?
Better to ask my mechanic. I have no idea, but said it wasn't a big job to replace sensor. He cleaned the connections and checked grounds before buying the sensor originally.
Liilpa09
Sep 28, 2021 05:16 AM
LIDB9
Dec 29, 2016 05:13 PM
zuman
Jun 18, 2016 11:53 AM
spawnywhippet
May 26, 2013 11:30 AM
62Jeff
Mar 30, 2012 08:01 PM
