DB9 Camshaft position sensor wiring
Old Oct 13, 2022 | 03:49 AM
Spannerdonkey's Avatar
Spannerdonkey is infamous around these parts
My db9 is throwing a p0340. I have already replaced the sensor itself and the 2 wires to the ecu checked out OK when it comes to resistance. I want to check the earthing but not sure where it should connect to the earth point. Can any tell me where to check?
It also show p0356, which is ignition coil. I have swapped over the ignition coil with another and the fault remains. Since it shares the earthing with the camshaft sensor I suspect this might be the issue.
Old Oct 13, 2022 | 04:41 AM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
On my 3 pin 2006 ignition coil there is a ground on the intake manifold/head near the back of the block. The coil wiring comes from the block to the back of the block and then goes left (or right) to the left or right ecu.
FWIW, I was getting similar unrelated sensor errors on mine. I pulled the front fender liner and took a look at where the wiring comes into the ECU. There was a lot of tension on the connector as the wires were sagging down. I removed the connector, put pressure on the wires to put them back into their individual connector and then re-hung the loom to avoid putting tension on the 40+ connectors. Since then (knocking on desk), I have not had any errors.
I also learned on my M5 to raise the hood after use to let it cool off. The hall effect sensors don't like heat as the high temperature causes the magnet to lose it's magnetism. My V12 feels like a furnace when I pop the hood. If you park indoors, it's worth considering.
Old Oct 17, 2022 | 02:22 AM
Thanks for the response, I've checked the wiring to the ecu and this should be all fine. Also i made sure the connector plugs are properly seated.
Checking the wiring schedule, it shows having a shared earth point with the ignition coil. Any idea where this earthing point connects?
Old Oct 18, 2022 | 03:38 AM
AM4884's Avatar
5 Year Member
There are 6 earth points on the fire wall, IIRC, 3 on each side, each with multiple small gauge ground wires attached. They are highly visible low down and then get progressively more covered by stuff as you get further up. Each of these can get corroded and the wires aren't particularly well protected. The wiring harness for the engine electronics uses these grounds. There is also one on the back side of the head/block on each side. If you look at a used wiring harness on ebay that can be helpful for figuring out how long the ground wires are and where they are located. Take a look, clean them up and make sure the wires are firmly attached.
Old Nov 1, 2023 | 08:51 PM
FloRen's Avatar
FloRen is infamous around these parts
Is it the 2 tabs at the bottom of this picture?
If it is, they are on top of the valve cover in the outside rearmost bolt.
I am having one continuous misfire and intermittent camshaft complaints
Old Nov 2, 2023 | 04:44 AM
AM4884's Avatar
5 Year Member
Those are the grounds on the back of the heads. I wonder if you have a failing connector (the white ones in the picture).
So frustrating. I would be tempted to add an additional ground wire directly to the cps & coil. Splice it in with the stock ground. 16-18 awg, high temperature (automotive grade) would work well. If you can twist and then solder it would be best. Put a heat shrink tube, or plastic dip coating on it.
The other frame grounds are up and down the firewall on either side of the engine as described above.
Good luck - without a doubt the most frustrating type of gremlin to chase.
AM4884's Avatar
5 Year Member
And, the picture of the harness is giving me flashbacks!
Old May 23, 2025 | 10:08 AM
jbranco's Avatar
jbranco
Sorry i know this is dated, but wondering if someone has resolved this? I just replaced my spark plugs/engine coils / injectors and just like the original OP, I am getting a P0340 for the CID sensor and also a DTC error code for ignition coil 1. I removed all the DTC codes and unplug the battery. Planning to reconnec tthe battery tomorrow ( doing a reset ) but unsure that will work..
Old May 24, 2025 | 06:09 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I am getting crank position sensor issues. Replaced the sensor, cleaned the connections and the problem persists. Will mention groundings to my mechanic. He tends to think it may be ECM related.
Old May 24, 2025 | 01:13 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Something like codes P0012 / P0013 / P0014 / P0019?
Old May 24, 2025 | 01:57 PM
5 Year Member
Originally Posted by ej_rapide
something like codes p0012 / p0013 / p0014 / p0019?
p1336
Old May 24, 2025 | 02:46 PM
EJ_Rapide's Avatar
p1336
Is it triggering a CEL, or is it just stored in the memory?
Old May 24, 2025 | 09:27 PM
jbranco's Avatar
jbranco
Do you mind sharing where the sensors for the camshaft are located? i have been trying to find a diagram that shows me where the connector/ sensors are to ensure they didn’t come unplug somehow while i was changing my spark plugs/ coils.
Do you need to remove the manifolds in order to replace the camshaft sensors?
Old May 25, 2025 | 09:49 AM
AM4884's Avatar
5 Year Member
I don't recall my DB9 (06) having camshaft position sensors as it doesn't have variable valve timing. The crankshaft sensor is located in the front of the engine block somewhere near the crankshaft . This diagram shows them as part #6
https://www.scuderiacarparts.com/par.../151/668/23917
Note that only one is actually connected... Another mystery of AM that there are two. Presumably at some point both ECMs required the crank position to fire.
Old May 25, 2025 | 06:58 PM
jbranco's Avatar
jbranco
Thanks for the diagram! Do you know why there is also the part number 7? Is that for timing rather than position?
i guess to access number 6 i would need to lift the car to access underneath, but at least i am glad no need to deal with the manifolds
