Catalytic Converters 2008 V8V
Old Nov 16, 2022 | 05:44 PM
Lefach's Avatar
Lefach is infamous around these parts
Anyone know the best place to buy Catalytic converters for a USA 4.3 2008 Vantage? And part numbers if possible? Oh and it's California so 200 cels won't pass inspection.
Thank You
Old Nov 17, 2022 | 08:13 AM
J doubleU's Avatar
Have you failed testing already? What do you currently have installed 200cel catalyst I'm assuming.
Old Nov 17, 2022 | 08:16 AM
Lefach's Avatar
Yes I have failed and no, stock cats.
Old Nov 17, 2022 | 09:19 AM
J doubleU's Avatar
Rare to have catalyst failure on a Vantage. Before you buy new OEM catalyst I would definitely have someone else check it out.
Old Nov 17, 2022 | 05:28 PM
SemiF19's Avatar
SemiF19 is infamous around these parts
I've been looking too. I got a P0420 code. Took it to a shop who did extensive testing on the O2 sensors and unfortunately determined the CATS were going bad. As stated above, I might get a second opinion. I have new O2 sensors on hand ready to install, and he did admit there is a tiny chance that was the issue, but was adamant he didn't think so. But I can't find new stock CATs anywhere online. Oh, and they are really, really expensive.
Old Nov 17, 2022 | 06:12 PM
J doubleU's Avatar
One very reasonable thing you can try for the P420 is oxygen sensor extensions they alter the the sensitivity of the downstream sensor to prevent the code from flagging. Since the sensors are mounted vertical there may not be enough room for a straight version, but they do make 90* ones that may fit.
JW
Old Nov 18, 2022 | 04:59 PM
SemiF19's Avatar
Finally found an online store selling new original OEM parts.
https://www.scuderiacarparts.com/]Car Parts Online | Performance Car Parts | Scuderia Car Parts
Part # is BG33-5E211-AB for the Right Converter, BG33-5E213-AB for the Left Converter
Not as bad as I thought. For both converters, and gaskets, with shipping came to $2767.
Old Nov 18, 2022 | 05:03 PM
Lefach's Avatar
Interesting, when I sent them a message to check my VIN I was told they were no longer available to order. This was yesterday.
Old Nov 18, 2022 | 09:07 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Did the car have a chance to warm up fully. You know at least 30 minutes of driving before you tested? There are posts related to the car not being driven enough before the test to get everything warmed up. Just a thought. I bet you can find used cat online much cheaper.
rolltide0323
Apr 10, 2020 12:23 PM
Loubell
Mar 5, 2011 06:29 PM
skandalis447
Feb 9, 2010 10:22 PM
Vantageman
Sep 18, 2008 12:54 AM
SAFE4NOW
Southwest
11
Sep 17, 2008 08:51 AM
