Boot Leak ??
Old Mar 26, 2023 | 12:56 PM
Tuddsy's Avatar
Tuddsy is infamous around these parts
Boot Leak ??
Hi guys, wonder if anyone can point in right direction. I have a boot leak on nearside rear. I thought it may be the rear lamp seals but after pulling back carpet and running water down rear screen to test, the water actually seeps out from under the boot trim (as per pic attached). If I pour water on top of the rear lamp, it obviously flows down the side and is then coming out from under the boot trim. I assume I ned to take rear lamp out to check, just wondered if there is anything behind there I should be checking for, or any ideas what may be causing the leak ?
Thank you in advance
My previous DB9 also had a boot leak, but was a dodgy boot seal. This seems to be entering elsewhere ?
Old Mar 31, 2023 | 10:33 AM
Theotherjames's Avatar
Theotherjames is infamous around these parts
I have the same thing on my DB9, although it's more towards the right side rather than your left side. It seems to happen more after I power wash it, rather than after a rain. I thought it might be the weather stripping, but the metal hump before the carpet is dry.
Old Mar 31, 2023 | 11:45 AM
Tuddsy's Avatar
It's going in to Dealer next week for service so will get them to investigate. Will let you know what they come up with
Old May 1, 2023 | 08:14 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
I just discovered this in my own trunk. Did you figure out the source? I cleaned the hatch drains and the seal under the glass passes a visual inspection but I can't figure out how, even with the drains clogged up, it would get over that lip seal and penetrate the trunk.
Old May 1, 2023 | 08:18 AM
Tuddsy's Avatar
Not got it back yet. Been a nightmare. Had a new SEN unit a few weeks ago as had weird electrical fault where after turning off ignition, the vehicle would not shut down properly (dials and radio etc would stay on). Did it again, and also locked me out for 3 days ??? So it is in at the moment and had a new fuse board somewhere that apparently full with water. They still have it for testing and not sure if they have done the rear leak yet, but as soon as I get it back, I will let you know.
Old May 3, 2023 | 09:57 AM
Marmot's Avatar
5 Year Member
The consensus elsewhere seems to be either clogged hatch drains (I've cleared them out with both blowing into them and vacuuming from underneath), a broken third lamp seal, or de-lamination of the floor area bonding to the rest of the bodywork. I can't verify the last one, but fingers crossed this is fixed. Hopefully yours is as simple Tuddsy.
rich9911
Bentley
Mar 24, 2023 08:47 AM
Raym50
Dec 13, 2020 08:38 AM
frank356
Nov 12, 2017 08:51 AM
steve.2.lowe
Bentley
Aug 9, 2017 11:18 AM
dporschey
Cayenne 955/957
Jan 10, 2012 11:12 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
