Anyone used the 08+ Vantage factory bluetooth audio upgrade?
Old May 4, 2023 | 12:33 AM
u2rnvs's Avatar
u2rnvs is infamous around these parts
Hi, I am looking to upgrade my '13 V8V to be able to use bluetooth streaming audio. AM has p/n FD43-37-10142 available as a kit to accomplish this. Has anyone used this kit and if so what is included, and also what is the OEM part number on the sticker of the new module?
Old May 4, 2023 | 06:15 AM
J doubleU's Avatar
The kit is an upgraded module that replaces the current one, and requires updated a new car configuration file that an AM dealer needs to install to work correctly with your existing system. Not a plug and play item.
Old May 4, 2023 | 08:24 AM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
I've got a kit sitting on my shelf for my '07 DB9 that will be getting installed soon. I believe the module is the same. FD43-14F191-AC. They pop up on ebay from time to time.
Old May 4, 2023 | 10:22 AM
u2rnvs's Avatar
So according to Aston FD43-37-10142 was superseded by FD43-37-10167.
J doubleU - do you know if there are any aftermarket programmers that do coding on these cars?
GA_DB9 - you hit the nail on the head, I want to try to find the module on eBay or through a recycler (Volvo apparently uses them) but need the OEM P/N for the version with streaming audio support. Aston has a different P/N for the pre-08 cars.
Old May 4, 2023 | 10:58 AM
Batman-76's Avatar
Batman-76 has a spectacular aura aboutBatman-76 has a spectacular aura aboutBatman-76 has a spectacular aura about
If you're in the SF area of San Francisco, Robbie has the ability to perform the required flash update.
I had the BT module updated by him years ago and have been super happy to not have to use the Tune2Air plugin any longer :-)
Old May 4, 2023 | 12:11 PM
GA_DB9's Avatar
5 Year Member
As far as I'm aware, there's one module in both pre and post '08 kits. It's just whether there's a new ICM, MOST harness, etc included. Someone that knows more than me can chime in. Here's the a pic of the module I have.
Old May 4, 2023 | 02:00 PM
u2rnvs's Avatar
Thanks, there are a couple of those on ebay for more than what AM wants new :P
Batman-76, unfortunately Im in AZ. Do you know what hardware/software he used to do your update?
Old May 4, 2023 | 07:51 PM
GA_DB9's Avatar
5 Year Member
u2rnvs,
Check out British Automotive Repair in Scottsdale. They specialize in AM and might be able to help. We visited their shop before moving from AZ to GA a while back and they seemed pretty knowledgeable.
Old May 6, 2023 | 06:37 PM
Batman-76's Avatar
Robbie has an AMDS computer. I'm not sure how often he gets updates from AM proper, but is able to flash a number of items.
I also had him assist with upgrading my base audio to premium audio - but we had to go back to AM proper to get the file.
Old May 8, 2023 | 10:35 AM
u2rnvs's Avatar
So I got this from an AM mechanic on Facebook;
• The hardware part numbers for the Denison don't officially matter, as far as the software required to run them goes.
• The "*.vbs" file (the flash-programming process control file used by AMDS and the like, to "control" what order the software is programmed) is named "BPM_0AAC.vbs".
• The required global parameter changes to the CCF in the CEM-P1x (Central Electronics Module - Platform 1x) are "125 - ZZ - After Production Changes = 0x02: Dension BPM Fitted". Changing this global parameter will cause the rest of the cars electronic architecture and topology to "recognise and allow communication" with the Denison BPM (if this CCF change isn't made, then the car will spit out a load of errors). If the car was manufactured before 2007MY, then the CCF also requires global parameter "105 - SA - Bluetooth Hands Free = 0x02: With BPM Bluetooth (MOST)" to be present (if not present already).
The Denison branded modules Ive found are FD43-14F191-AB or FD43-14F191-AC which are likely to just be different revisions of the same thing.
Old May 8, 2023 | 10:36 AM
u2rnvs's Avatar
I dont believe I know Robbie...?
Old Jun 25, 2023 | 12:33 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Have you had a chance to complete the installation?
Adding the BT streaming would be an amazing addition!
Old Jun 25, 2023 | 11:00 PM
u2rnvs's Avatar
The physical installation is super simple but I havent really had the time yet to look for someone with access to code modules.
Old Jun 26, 2023 | 01:45 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Every year I say I am going have the dealer install this and then forget or skip. Thanks for the reminder again.
Old Jun 26, 2023 | 08:48 PM
EJ_Rapide's Avatar
Do we maybe know of any equivalent Volvo or Land Rover part number?
