OBDII On 2020 DB11
Old Jun 1, 2023 | 11:24 AM
eroc0808's Avatar
5 Year Member
eroc0808 is infamous around these parts
OBDII On 2020 DB11
Hello friends! I had to remove a seat out of a 2020 DB11 for a repair. Since seat was removed it triggered the airbag light and I need to reset it. I only see one OBD port in this car and it only gives me engine codes. Is there a second OBD that does all the body codes like the older Astons? If so, any guidance on its location? Thanks!!!!!!
Old Jun 1, 2023 | 11:58 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Hi @eroc0808,
The OBD II port is the one source for all fault codes (B-codes, C-codes, P-codes, and U-codes) on this MY DB11. Problem is the tool, especially if it is a V12. A simple OBDII scan tool will only retrieve P-codes. You need a deeper scan tool to extract any other codes, or to reset certain functions such as SRS. Unfortunately, I cannot say there are any tools I've run across that can work on this system.
If you have the AMG V8, there is a possible better chance using MB compatible deep scan tools (maybe). Since I have the V12 in my DB11, I am "on the hunt" for scan tools and yet to find one, but also cannot experiment with some tools I have that work on the AMG platform.
Sorry this is probably not much help for you....
Old Jun 1, 2023 | 01:04 PM
eroc0808's Avatar
5 Year Member
Originally Posted by BWings
Hi @eroc0808,
Thank you for the reply! I was afraid of that. I'm using the AUTEL MAXISYS ELITE that works on anything but this so I suppose its not compatible at the moment. I do believe this car is a V8, not near car at moment though, so maybe I'll run through a few Benz settings and see. Oh well. Thanks again.
Old Jun 1, 2023 | 01:19 PM
BWings's Avatar
5 Year Member
Yes, one of my favorite tools is an Autel Mx808. I used it extensively on my AMG GTS. it read every module and I could reset many functions.
If I had the V8 I would try using the MB settings but NOT try reading the VIN. Just go directly to diagnosis.
Here is a typical printout of a deep scan on the GTS
Old Jun 1, 2023 | 02:36 PM
eroc0808's Avatar
5 Year Member
BWings you're the best!!!! I went in under the Mercedes protocol and swept everything. Air bag light is now extinguished. Thank you for the tip.
Old Jun 1, 2023 | 02:47 PM
BWings's Avatar
5 Year Member
Glad it worked and the info you just provided is invaluable insight for me.
Thank you!
Duane
Oct 28, 2021 11:25 AM
JSBear
May 31, 2016 01:07 PM
Idoktr
Jul 18, 2015 12:20 PM
xxaarraa
Oct 8, 2013 07:44 AM
andreas
Aug 18, 2004 01:54 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
