2020 Vantage rattle in hatch
Old Jun 9, 2023 | 01:58 PM
Rjscharer's Avatar
5 Year Member
Rjscharer has a spectacular aura aboutRjscharer has a spectacular aura aboutRjscharer has a spectacular aura about
Anyone experience a rattle in their rear hatch cover in all types of road surfaces?
Old Jun 10, 2023 | 04:10 PM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
Yes. Try adjusting your trunk lid buffer stops.
see https://www.astonmartinbits.com/mode...age/parts/4601
Old Jun 10, 2023 | 06:55 PM
Rjscharer's Avatar
5 Year Member
Much thanks!
Old Jun 11, 2023 | 09:20 AM
MikeR397's Avatar
MikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant future
Yes, my rattle is from the leather privacy cover fixed to the hatch. This just pops right off so you can remove it to test if that's the issue. The solution is to shim the plugs/sliders a little with something to remove any excess play.
Old Jun 11, 2023 | 10:20 AM
Rjscharer's Avatar
5 Year Member
Will try….tanks much.
Old Jun 11, 2023 | 12:23 PM
J doubleU's Avatar
Also make sure the 2 screw-in ball ends for that panel are secure. Heat shrink tubing works well on the front dowel mounts.
-JW
Old Jun 11, 2023 | 01:57 PM
Rjscharer's Avatar
5 Year Member
That was it. Two screws on each fitting were quite loose. Only 900 miles on the car so they weren’t loosened through use.
Old Jun 11, 2023 | 02:08 PM
J doubleU's Avatar
Hand built=finger tight. Glad you solved it and updated for others.
-JW
Old Jun 11, 2023 | 02:19 PM
Nice. Glad to hear this was solved.
LμL
Mar 13, 2023 10:05 PM
Prefurbia
Oct 15, 2021 10:26 AM
Mark8V8
Aug 13, 2015 11:31 AM
captain Greg
Mar 25, 2014 11:51 AM
