Help! Weird water marks underneath headlight after PPF? V8V
Old Aug 3, 2023 | 04:46 AM
VintageCarCollector_5999's Avatar
VintageCarCollector_5999 is infamous around these parts
Hi guys,
I recently had XPEL PPF installed on my V8V's headlights. And after doing that, a line of water marks have formed underneath the headlight covers?
It's been a few days and it seems to be staying.
They don't seem wet. Just seems dry/hazy.
Any idea what this is and how to rid it?
Old Aug 3, 2023 | 05:23 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Not sure I see what you are talking about.
Old Aug 3, 2023 | 05:25 AM
Old Aug 3, 2023 | 06:22 AM
5 Year Member
Those look like reflections off of the film.
Old Aug 3, 2023 | 09:40 AM
MRCW's Avatar
I had mine done Few years ago and had this... it was some remaining liquid that they used for application and it eventuality went away after a couple of days.
It could also be a bubble that they didn't get out.
Don't try to remove the film. There is a layer on thy light that could come of and then it will be talky hard to fix
Old Aug 3, 2023 | 11:23 AM
They aren't reflections. They're there even if the lights aren't on.
The problem is it seems to be underneath the plastic light cover not on the cover?
Old Aug 3, 2023 | 11:31 AM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
It's an unacceptable job. Needs to be redone. Take it back.
Old Aug 3, 2023 | 12:06 PM
Is it a glue stain? Because it doesn't seem to be underneath the PPF. It seems to be underneath the plastic light cover itself. (Not above it).
Old Aug 3, 2023 | 12:21 PM
5 Year Member
Oh, I thought it was under the PPF. You will need to remove the lights and the bulbs to get inside to clean them if possible.
Old Aug 3, 2023 | 03:01 PM
MRCW's Avatar
When they put this on they often heat them ... perhaps the heat gun caused this issue?
Old Aug 3, 2023 | 04:40 PM
Hedged's Avatar
Hedged is a jewel in the roughHedged is a jewel in the roughHedged is a jewel in the rough
Another general caveat regarding PPF applied to Aston headlights....Be very careful with cleaners & solvents during application (can’t recall if alcohol or petroleum is the culprit) as the existing OEM headlight film can degrade. The OEM film is a UV protectant (not a PPF) and looks pretty bad if chemically degraded.
Old Aug 3, 2023 | 09:34 PM
Is this an easy procedure? Does it involve resealing again? Do I have to take out the entire fender?
Im honestly not sure. It only developed after a few days and seems to follow the LED lights positions?
Does this look like chemical damage?
Has anyone not experienced this before and know what it is?
On another note, do you guys think it's necessary to PPF the headlight? Did I make a mistake by doing it?
Old Aug 4, 2023 | 09:37 AM
5 Year Member
Wow, I would be so upset as well. I didn't know they used heat when applying PPF, or if so, I can't imagine it would be so hot to create damage. I would have the PPF removed and go from there. The lights are removed from inside the wheel well, but have no idea if they are sealed, if so may be no way of cleaning inside. Might need to be replaced if the damage is inside. Hopefully someone on might know.
Pangerz
Jan 16, 2023 12:53 PM
MalcolmV8
Apr 10, 2015 09:09 AM
FI_FTW
Nov 25, 2013 07:12 PM
Turbohead
Aug 22, 2007 07:09 PM
andreas
Lamborghini
Dec 6, 2005 12:33 AM
