Interior color change
Old Oct 9, 2023 | 05:56 PM
trainwreck's Avatar
trainwreck is infamous around these parts
Here’s the exact look I’m going for. I just received my dye. And starting to remove the easy bits for clean and prep.
https://bringatrailer.com/listing/2006-aston-martin-db9-volante-28/
Old Oct 9, 2023 | 08:47 PM
trainwreck's Avatar
Couldn’t wait. Had to test a small area after getting some inspiration
Old Oct 9, 2023 | 11:57 PM
MRCW's Avatar
looks pretty good. what are your doing for the stitching?
on larger pieces will you mix bottles together?
Old Oct 10, 2023 | 04:41 AM
trainwreck's Avatar
For these small pieces. I did a really good cleaning with dawn and warm water. Then used a scuff pad. Very happy with the results. I have a liter of color. Which is their largest size. It took 3 thin coats to get good coverage. But does not seem to be a lot of usage. According to their site it is enough to do an entire interior. So I was not planning on having to order more let alone mix.
We’ll see how that goes. As I am working from rear to front
Old Oct 10, 2023 | 09:33 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
That's very cool! How will you get the dye out of the stitching?
Old Oct 10, 2023 | 05:45 PM
trainwreck's Avatar
🙄 not an option sat this point. But if you have any suggestions…I’m all ears. 😝
Old Oct 10, 2023 | 06:30 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
That’s gonna be a ton of work…can’t wait to see finished pictures…
Old Oct 11, 2023 | 01:35 AM
Grateful's Avatar
Grateful
Great work. On my M5 I did something similar to restore the interior. I didn't do a color change (I should have once I found out how simple the process is). I used acetone to strip the dye, then used an air brush to redye the seats and finally used a clear coat. I used dye from furniture clinic. One thing that helped was once I had the process down and bought enough dye to do the entire interior at once to make sure there were no color differences if I bought the dye in separate batches. Aston leather is different but at the end of the day it's just leather. Just take your time and it will turn out fine. For inspiration lookup how people redye leather shoes, handbags and car interiors on YouTube.
Before:
After (Clearcoat was still wet):
Hope this helps!
Old Oct 11, 2023 | 11:56 AM
Pangerz's Avatar
5 Year Member
Pangerz is infamous around these parts
That actually looks great!!!! Looks so even in the pics - is the coverage even in real life??
Will you be finishing it with something or is a dye job all you need?
Old Oct 11, 2023 | 01:34 PM
trainwreck's Avatar
Yea the coverage is even in real life. Really pleased with this product. I have been using the supplied sponge to “blot” the dye. Then a blow dryer to dry between coats as recommended. But after dyeing a the bottom of the rear seat I feel it’s better to use an air sprayer to really get that professional finish. So I will work on complete removal of all the interior and prep so I can spray it on. But I’m very ecstatic 🤩 about the finished product!
800 grit scuff pad
Side by side
Looks and feels so supple
Old Oct 11, 2023 | 01:40 PM
trainwreck's Avatar
Before:
Hope this helps!
thanks. Looks great. Had a chance to pick up an e39 m5 a few years back for a really good price and passed. Kicking myself for that one. I have owned 3 e39’s over the years tho. Awesome cars. Love/hate relationship. But overall one of the best and truly classic. I have an f10 now and wife has an f15. Love Bmw as a daily!
Old Oct 11, 2023 | 02:32 PM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Hi @trainwreck
You're doing a fantastic job! keep going. You're going to be proud of the project you took on and succeeded! Looking forward to more pics!
Old Oct 11, 2023 | 04:00 PM
trainwreck's Avatar
So most of the rear is out. Any pointers diagrams on removing the side panels? Haven’t really attempted yet. But any tips to make it go faster…
Old Oct 11, 2023 | 04:57 PM
Grateful's Avatar
Grateful
I do miss mine, one of the best sounding cars ever IMO. Congrats on the F10 and F15! That red looks gorgeous. That's the color I wished I used on the M5 and my volor of choice for a Vanquish.
Old Oct 12, 2023 | 09:05 AM
Marmot's Avatar
5 Year Member
I'm curious how you removed the central vertical rear panel that sits in front of the trunk, above the parcel shelf. I've been considering putting some dynamat behind that to cut down some of the low frequency tire noise.
