Rapide No Rear Belt in use Error
Old Nov 18, 2023 | 11:06 AM
zzzamdb9's Avatar
5 Year Member
zzzamdb9 is infamous around these parts
I've noticed sometimes my car says "no rear belt in use." If i restart the car it goes away. Any ideas? Thanks!
Old Nov 18, 2023 | 11:31 AM
UltraMarine's Avatar
UltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to all
It always says that if you open the rear doors, whether you use the rear seat belts or not. Just acknowledge it with the Info button and it goes away.
Old Nov 18, 2023 | 05:59 PM
zzzamdb9's Avatar
5 Year Member
If I click read it is still stored as a message unless I restart the car. Is that normal behavior?
Old Nov 18, 2023 | 06:01 PM
Yeah, mine does that too. It stores the message but doesn't display it unless I cycle through the info message for that drive. Afterwards when I restart the car, it goes away.
Old Nov 18, 2023 | 06:10 PM
zzzamdb9's Avatar
5 Year Member
Sounds like normal behavior. Thanks for confirming!
Old Nov 19, 2023 | 10:12 AM
zzzamdb9's Avatar
5 Year Member
I found out in the manual there is a way to disable the message.
To Disable or Enable the Rear Seat Belt Reminder
• Make sure that the ignition is set to OFF (ignition position '0') and
that both rear seat belts are unfastened.
• Set the ignition to ON (ignition position 'II') and within 60 seconds
fasten and unfasten a rear seat belt nine times. Finish with the belt
unfastened.
• The message ENABLE/DISABLE REAR SEAT BELT REMINDER? will
show in the message centre (right). Within five seconds fasten and
unfasten the rear seat belt once more.
• The conformation message REAR SEAT BELT REMINDER
ENABLED/DISABLED will show for 30 seconds.
The warning messages are always available, press the READ button to view stored messages.
V12Stealth
Sep 16, 2023 01:38 PM
iambon
Apr 9, 2020 08:24 AM
mm450exc
Aug 31, 2012 09:33 AM
LT1
993
Apr 29, 2010 08:09 AM
