2013 DB9 dead spider in headlight
Old Dec 4, 2023 | 08:51 PM
AM-DB9.2's Avatar
AM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of light
Hello,
Has anyone had this issue and/or know how to remove the little buddy?
It is sitting at the very front of my headlight, very visible, very annoying.
Old Dec 7, 2023 | 05:20 AM
bobdisp's Avatar
5 Year Member
bobdisp is infamous around these parts
Did your friend find his way out? He had the view of a nose bomber gunner!!
Old Dec 8, 2023 | 03:39 PM
AM-DB9.2's Avatar
not yet
Old Dec 8, 2023 | 05:14 PM
Viper98912's Avatar
5 Year Member
Viper98912 is a jewel in the roughViper98912 is a jewel in the roughViper98912 is a jewel in the rough
Unfortunately you're probably going to need to take out the headlight and try to shake it out of whatever tiny hole it crawled through. If it's dead state is bigger than the hole, then you might need to take out the projector to make the exit larger. No easy way unfortunately.
Old Dec 8, 2023 | 05:31 PM
AM-DB9.2's Avatar
Hi,
By projector, are you referring to the lens in front of the HID bulb?
Would the lens be sealed or would it pull out from the backside, I wonder?
I am thinking if I can gain access, even through a small hole, i could use a very long straw attached to a vacuum to suck it out.
this is my headlight type...
Old Dec 8, 2023 | 08:00 PM
J doubleU's Avatar
I would try a small nozzle and lots of dry compressed air after removal of the HID bulb. At least it may come out in pieces without removal of headlamp.
Old Dec 9, 2023 | 06:25 AM
Viper98912's Avatar
5 Year Member
Yes, the projector is the housing that holds the glass, bulb, and reflector, as one unit. Now, I have never taken apart an Aston martin headlight, but most headlights are normally built with the projector as a separate unit that's bolted into the headlight assembly with ~4 screws. It might take some disassembly to get there, but there's a potential that this may be the easiest way, AFTER trying the straw method. There's probably a small weep hole (condensation hole) where the spider first crawled in; tape a straw to your vacuum cleaner and see if you can suck it out first.
PJK
Oct 4, 2023 03:29 PM
powerbeautysoulAM
Nov 14, 2016 03:23 PM
Wildcat1212
Oct 19, 2015 08:51 AM
brian sherwood
Jul 3, 2013 06:24 AM
CarPoint
May 14, 2013 01:28 AM
