2005 DB9 Volante - Roof Movement Paused
Old Apr 27, 2024 | 05:16 AM
Hamodi's Avatar
Hamodi
Hi all,
DB9 has recently started to show "Roof Movement Paused" error every time I try to raise and lower the roof.
The roof still lowers completely fine but when it reaches the end of the cycle it doesn't say "Movement Complete" as it normally should, and once I release the switch it will come up with the "Roof Movement Paused" error.
When trying to raise the roof back up, everything functions normally but when the roof is about 2 inches away from the windscreen it stops, but if I release the switch and press again, it fully completes the cycle. But again, it doesn't say "Movement Complete" and eventually when I release the switch it will come up with the "Roof Movement Paused" error.
The only way I can get around having this error show on the screen and it constantly beeping as I drive is to lower the roof, lock the car, unlock it again after a couple of minutes then drive it with no errors showing.
I would appreciate any pointers or troubleshooting steps if anyone has come across this before. I've seen a few threads on the forum where either the motor wasn't working, the roof latch wasn't clicking in place, the windows weren't going up, etc. but it seems like my issue is different from those as everything is working as it should but it's registering this error.
Many thanks in advance!
Old Apr 28, 2024 | 06:11 PM
MikeD's Avatar
MikeD is infamous around these parts
Have you reset the windows? That's a common problem. Low voltage or a battery change can mess up the roof movement. I'd make sure you have a good battery, fully charged, and reset the windows. If that doesn't help, your roof module may be on the fritz. Mine failed over a period of 10 or so drives. Other weird errors appeared and eventually my roof (and some instruments) didn't work. A new roof module cured everything.
Old Apr 29, 2024 | 04:16 AM
Hamodi's Avatar
Hamodi
Hi Mike, thanks for the pointers. I did notice last week that the passenger window was stopping about an inch from the top and I had to let go and pull the switch again to make it reach the top. I did reset the window after noticing that and that has fixed the passenger window issue. I was really hopeful that would fix the roof error but unfortunately not.
Thanks for letting me know about the roof module. Could you let me know where this is located and are there any troubleshooting steps or is it just a matter of swapping it out for a new one and hoping that resolves the issue?
Old Apr 29, 2024 | 11:20 AM
Hamodi's Avatar
Hamodi
Something I just noticed which might help in troubleshooting this...
As previously mentioned, after closing the roof and letting go of the 'roof close' button, it says "roof movement paused". However, if I pull the 'roof close' button again, I notice that for a split-second it will try to raise the passenger window, almost as if it thinks it isn't fully closed but it already is. I notice that it will keep doing this whenever I release and re-engage the 'roof close' button. The driver's side window does not react in the same way.
I've already tried re-calibrating/resetting the windows on both sides but thought I would mention this in case it means anything to anyone?
Old Apr 29, 2024 | 05:59 PM
MikeD's Avatar
When my roof module began to fail, there were additional symptoms that I presume you haven't experienced (like the instruments not working intermittently).
Sounds like your windows need to be reset. Do this when you have the roof up and latched. Put the driver's window down and continue holding the switch for several seconds, then raise the window, again holding the switch for several seconds. Do the same with the passenger's window. Then, using the roof button, do the same for all the windows together. I think that might solve your problem. Fingers crossed.
If and when you need to replace your roof module (which is probably just a matter of time), you'll find it behind the driver's side rear fender liner, which is accessible after removing the wheel.
Old Apr 30, 2024 | 01:48 PM
Hamodi's Avatar
Hamodi
Thanks MikeD. The car isn't displaying any other symptoms. I tried the window reset again on both sides but unfortunately no difference. I didn't understand the bit you mentioned about using the roof button to do the same for all the windows together? Do you mean close the roof but hold down the button to also reset the system? If so, I have tried that also. As soon as I eventually let go of the button, the error message will display.
Old Apr 30, 2024 | 06:09 PM
MikeD's Avatar
I looked back at an old post of mine and it refreshed my memory.
The roof switch is the only means of raising and lowering the rear windows. You need to get the rear windows all the way up before you reset the front windows.
Old Jun 17, 2024 | 04:03 AM
Rush42's Avatar
Rush42 is infamous around these parts
Possible Tonneau Latch "sensor" failure
Hamodi, sounds like it could be the same issue I have; In my case
  • roof movement could be completed both up and down
  • Tonneau cover latches engaged/disengaged properly both isdes
  • Movement would always pause and I had to press and hold at least twice to get the movemnet to fully complete
  • I always got the roof movement fail warning.
The issue was traced down to a micro switch on the tonneau latch assembly itself.
It does not appear (that i have found) on the main parts diagrams but can be seen on the wirining diagrams.
The micro switches act as a safety system and signal when the latch is fully closed, and if they fail the CRM does not know the latches are secure (even though they are), and will thus issue the warning.
I found this out after taking it to a specialist who did a quick fix... which i later found out was to bypass the faulty switch by cut/twist of the sensor cable that can be found behind the rear seat..
Anyway - if this is the issue and you want to fully fix (eg not just quick fix above) you need to replace (or may be adjust?) the midroswitch or replace the latch assembly.
I am on this pathway now (awaiting a dry spell.....) but the latch replacement procedure is sparse on detail (remove roof, remove latch..etc ) and the latch assembly is attached to the tonneau motor buried in the rear wheel arch by a worm gear/cable.. so not sure if it is so easy to just "replace" without detaching the drive cable from the tonneau latch motor (deeply buried in rear wing as per other threads).
Roof is apparenty held on by just 6 bolts, and you definitiely need to remove the roof to get proper access to the latch assembly bolts / microswitch.
I have not seen/found another thread on latch replacement or roof removal, one was started by OldOhart (https://www.6speedonline.com/forums/member.php?u=98815) but never updated with the final procedure..
Anyway, hope thats of some help.....
Old Jun 17, 2025 | 11:21 AM
rcf's Avatar
rcf
rcf
Volante Roof Module - Repair
The roof modules fail. Some guys in the UK have figured out how to repair them
wwtxamdb9
Nov 9, 2020 08:19 PM
chriscmore
Nov 3, 2018 09:07 AM
Juanna Knowtrooth
Cayenne Turbo
10
Jan 5, 2017 04:44 AM
zuman
Aug 18, 2016 01:51 PM
Subbie
Cayenne 955/957
Apr 15, 2008 07:52 PM
