Vantage - Two Different Times Showing
Old May 22, 2024 | 03:35 PM
christopherlem's Avatar
5 Year Member
christopherlem is infamous around these parts
All - my MY106 GTS displays the time in the gauges as X but in the infotainment as Y. They are off by two minutes. They were originally synced when we replaced the battery but somehow fell out of sync many months later. I have seen this before and it rectified itself only to happen again. I did go and manually re-set the time but that didn't work. Anyone experience this and or know how to fix?
Old May 23, 2024 | 05:16 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
The clock on the center console runs fast. Not sure why they don't have them both sync when Nav is turned on?
Old May 23, 2024 | 08:01 AM
5 Year Member
@brightoncorgi have you seen this issues with your Vantage as well? Did it ever fix itself or the two stayed out of sync forever?
Old May 23, 2024 | 08:09 AM
5 Year Member
I've seen on both my previous V8V and now Rapide. The issue never fixes itself. I generally would have the sync them on my annual service, but it was about an hour labor to do so. I did not sync it on the last annual.
Old May 23, 2024 | 10:20 PM
J doubleU's Avatar
If you are brave enough to do a battery reset it will solve your issue. An hour charge at the dealer is absurd. Just passing on free information.
-JW
Old May 24, 2024 | 06:05 AM
5 Year Member
-JW
Service tech's said they need to be adjusted via ADMS or something behind the center console. I forget. They adjusted it for free a couple of times too.
Old May 24, 2024 | 08:19 AM
J doubleU's Avatar
There is a connector at the RH side console the feeds the center panel.
No AMDS magic involved. Hard reset is what the fix is.
Old May 24, 2024 | 10:19 AM
5 Year Member
How does the time get set after the reset?
Old May 24, 2024 | 11:20 AM
J doubleU's Avatar
GPS sets the mechanical clock.
Old May 26, 2024 | 11:43 AM
5 Year Member
Somehow missed all these replies but thank you! What does the battery reset entail? Just disconnecting and reconnecting?
ljp997tt
May 31, 2023 05:29 PM
jdarland996
Jul 3, 2021 05:29 AM
captain Greg
Apr 18, 2016 12:10 PM
rohnin
Oct 23, 2015 11:51 AM
