HELP: Wiper Park Position Issue
Old Dec 6, 2024 | 11:22 PM
tech15's Avatar
tech15
Hello.
2015 Vantage V8
* The wipers are parking in random positions across the windshield.
* The wipers will not stop when set to off until 10-15 wipe cycles have been completed.
* Removing the ignition key does not stop the wiping immediately. (This could be normal - not familiar with vehicle)
* Wiper motor has been replaced for this issue - no change.
* Swapped out wiper relay.
* When operating, the sweep is normal/complete. No backward motion into the cowl or hitting of the A-pillar.
* Is this a valid/applicable part (37-123781-AB - AKA "Wiper Relay Module) for this vehicle and if so, where is it located?
I'm looking for suggestions, and clocking procedure of wiper motor (with images or diagram) after replacement.
Thank you
Update: CCM had corrosion on the printed circuit. Replaced and normal operation was resumed.
VantageS
Aug 29, 2025 02:24 PM
Dax88
Feb 5, 2024 10:19 PM
bknight
Jun 22, 2021 12:48 PM
Prefurbia
Jun 29, 2017 06:51 PM
