DB7 Vantage MY2000 stop lamp failure....losing my hair over this
Old Nov 5, 2015 | 02:07 PM
bknight's Avatar
bknight is infamous around these parts
Hello to everyone. Looking for any help I can get. Took the car in for an annual PA inspection and the stop lamps would not work. The mechanic and I went over everything (lamps, fuses, relay, broken circuit, brake switch) and all were fine. Using the DB7 Workshop Manual, Circuit Sheet 11, the circuit includes the gearshift interlock module, ABS ECU, key transponder module, OBDII connector and Diode 9. The brake petal switch has power to both sides which I think rules out the key transponder and the OBDII connector. I tore apart the center console and replaced the gearshift interlock module to no avail. I have no idea where to find the ABS ECU or Diode 9.
Has anyone experienced a similar issue? All help is appreciated.
In an (hopefully) unrelated issue, the dash airbag light had come on. Based upon the flashes there is "high resistance at the squib(sp?). Any ideas where to find the "squib"?
My best to all.
Old Nov 5, 2015 | 03:10 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Not many DB7 owners here. You'll have better luck at amoc.org in the Bloxham section -- it's quite active, with lots of DB7 expertise.
Old Nov 5, 2015 | 05:30 PM
XJRS Owner's Avatar
+1 to the above
Old Jun 22, 2021 | 12:48 PM
konguid's Avatar
konguid is infamous around these parts
2001 DB7 Vantage V12 Stop light failure
Having the same issue you had, were you able to solve it and how?
thanks,
Gene G
Sep 22, 2023 12:59 AM
polutski
Oct 28, 2017 01:13 AM
DocGaw
Jun 24, 2016 11:03 AM
robertwroth
Mar 1, 2016 12:22 PM
tsweat
Sep 17, 2004 08:00 AM
