'08 Vantage front sensor location
Old Jan 22, 2025 | 09:40 AM
Bassman12's Avatar
Bassman12 is infamous around these parts
Does anyone know where the front impact sensor location is ?
I have an error code "Front Side impact sensor B Pillar". Front and B Pillar seem contradictory. Ive replaced the sensor behind the seat below the B Pillar but was confused by the word Front in the error code so now I suspect the Front sensors. It's not under the large Aluminum plate over the radiator and AC condenser. I also don't see it under the front vinyl wheel arches.
Old Jan 23, 2025 | 01:53 PM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
What is the actual P or B code from your OBD tool? A generic code reader might not give you the specific Aston error. It might be fair translation of that code to say, "Front passenger side impact sensor (maybe B pillar)". Keep in mind that just because that sensor is erroring doesn't mean it's bad. It could be the airbag control module or a wiring defect between the module and the sensor, for example.
Old Jan 24, 2025 | 09:34 AM
Bassman12's Avatar
The code is P00CE. from a Foxwell NT520 Pro scanner < Front side impact sensor (Right B pillar) Sensor error >. . If I could find the 2 front sensors I could swap the 2 sides and see if the OBD2 reader possibly gives the same code with (Left B Pillar). (?). I found the sensors behind the seats (B-Pillar) and shaped both with a new part with no change to the code reader message. Thanks
Old Jan 24, 2025 | 09:53 AM
GA_DB9's Avatar
5 Year Member
That's actually pretty confusing. P codes are for powertrain. I would've expected a B code for the impact sensors. P00CE should be something more like "Intake air temperature measurement - multiple sensor correlation issue."
Does the code cause a check engine light or a stability control system fault?
Old Jan 24, 2025 | 10:10 AM
Bassman12's Avatar
The car dash reports < SRS Airbag Service Urgent >. The scanner was plugged into the Body OBD2 port. I thought my swap idea might save a trip to the dealer.
Old Feb 1, 2025 | 09:10 AM
Bassman12's Avatar
I found the front crash sensors located on an aluminum bracket contains the hood latch right in front of the radiator. Access it by removing 12 T30 bolts securing the large aluminum panel. The two sensors face the rear of the car.
exilebrit
Jan 24, 2024 07:50 AM
anton28
May 6, 2023 10:41 PM
oo7
Sep 19, 2019 07:25 AM
TO08TURBO
Aug 3, 2010 07:26 PM
DNugget991GT3
Aug 19, 2008 10:21 AM
