2010 amv8v exhaust bypass solenoid wire
Old Jan 28, 2025 | 03:03 AM
jpfredette's Avatar
5 Year Member
jpfredette is infamous around these parts
I am looking for the wire at the ecm connector that serves the exhaust bypass solenoid; I would like to install a switch to manually control the exhaust bypass valve, and would like to accomplish this in the passenger/driver compartment rather than at the right rear wheel where the solenoid is located; does anyone know the ecm connector position or wire color for this?
Old Jan 28, 2025 | 05:53 AM
PhuketPaul's Avatar
PhuketPaul is infamous around these partsPhuketPaul is infamous around these parts
I installed a 3 way exhaust switch (Auto/stock - loud - quiet) on my DB9, write up with wiring locations etc, is below
https://db9s.com/aston-martin-3-way-...exhaust-valve/
Old Jan 28, 2025 | 06:16 AM
jpfredette's Avatar
5 Year Member
yep paul, that's here I got the idea!; now I just have to identify my solenoid wire!!
Old Jan 28, 2025 | 06:18 AM
jpfredette's Avatar
5 Year Member
I got a copy of the workshop manual and scrutinized for ecm pinouts but couldn't find the schematic i need.
Old Jan 28, 2025 | 06:29 AM
jpfredette's Avatar
5 Year Member
does your db9 have 3 connectors to the ecm?; if so, which of the 3 was the white wire??; perhaps mine is similar enough that I can measure with a voltmeter while racing the engine.
Old Jan 28, 2025 | 10:01 AM
PhuketPaul's Avatar
The Vantage wiring is the same as the DB9, look for the connector in the front footwell with a white wire at Pin 19.
Old Mar 9, 2025 | 10:04 AM
jpfredette's Avatar
5 Year Member
hi paul,
the central electronic module is located either in the passengers-side or drivers-side footwell of my 2010 amv8 vantage; can you instruct how to remove access panels to access? ... your db9 access is similar?
-jim fredette
AM v12v
Jun 24, 2019 10:12 PM
Siy
Bentley
Oct 23, 2014 02:20 AM
drt50
May 12, 2014 11:04 AM
rmrmd1956
Aug 1, 2011 04:30 PM
