2015 Vantage 3rd Gear Grind
Old Mar 21, 2025 | 11:24 AM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
Originally Posted by embdenb
I believe its synthetic. Should last seven to ten years. At my age it might outlive me (smile)
True, but then it will be in the car for another 4 years or so. Hopefully you will far outlive your BOT 270A!
Old Mar 25, 2025 | 07:26 AM
wilhit10's Avatar
wilhit10 is infamous around these parts
I drained the gear box fluid and it had a nice sparkly glow to it when I shined the flash light on it. Since I had recently changed the gear box fluid, I decided it was better to order a used trans to replace this one. I got this car with a bad motor, so I guess it had a bad trans too. Anyways, I'll hopefully get the new transmission this week.
FYI, it happened when it was hot and cold. You could do a delay and shift, so I am pretty sure it ate a synchro.
seastu
Jul 5, 2022 10:25 AM
Gene G
Apr 18, 2021 09:06 AM
Prefurbia
Jun 29, 2017 06:51 PM
georgemaser
Oct 17, 2015 05:59 PM
terminal_ac
Sep 2, 2014 11:36 PM
