X pipes on DB11 V12 or not?
Old May 2, 2025 | 01:14 PM
meteoritesilver's Avatar
meteoritesilver
On my DB 11, I already did the VAP ECU upgrade the 750 hp, down pipes without catalytic converters. Sounds glorious. Thinking about deleting muffler box and replacing with X pipes. If I go X pipes will I lose bottom torque? Will I lose any of that signature Aston Martin muscle car sound? Thanks!
Old May 3, 2025 | 05:24 AM
embdenb's Avatar
Not sure X pipes on a V12 improves anything.
Old May 3, 2025 | 07:55 AM
momo stallion's Avatar
momo stallion is infamous around these parts
What is the goal of the change? Louder or different sound characteristic?
I wouldn't worry about torque, especially on anything turbo. Not sure how it changes the TT V12 sound note but for the N/A V8 & V12 cars, an x-pipe quiets down idle and calms that low-rpm "thunder" shifting it to a higher-pitched, raspier, top-end scream usually associated with more of an exotic car vs muscle car. The middle of the rev range isn't drastically different between straight pipe vs x-pipe.
Just my opinion, I personally love the x-pipe as a secondary delete on the N/A V8 cars. For the V12 cars, I prefer the straight pipe secondary delete if just wanting to amplify sound output.
Note that everything does does depend on the rest of your exhaust/backbox combination too... (i.e. I loved my v12 w/ quicksilver backbox sound until I did secondary deletes. It was louder but more muscle car than I wanted and the lack of valves just made it a bit too loud at highway cruising speeds. I swapped the quicksilver backbox for a VAP valvetronic and now it's a great cohesive sound again).
Old May 3, 2025 | 08:11 AM
meteoritesilver
Thank you, that was amazingly helpful.
You’re the first person I spoke to that knows that much about this stuff. That’s what I was looking for. So just to be clear, I have the TT V12 , I removed the catalytic converters and put down pipes. I have the velocity 750 hp upgrade.
It is a lot louder from stock, which is what I like. If I can have two things only without changing anything else, I would have just a little bit more scream in the higher revs, and for the entire volume decibel to increase about 20% 40% more.
That being said, how do you think X pipes and muffler box delete will impact the tone that I currently have?
Old May 3, 2025 | 08:48 AM
I don't see that VAP has anything X pipe for the DB11 but this is a vid from VAP that says straight piped db11 v12 (and it sounds awesome) so I would guess that is a muffler delete with what you already have:
Porsche951S
Cayenne 955/957
Jul 3, 2012 03:42 PM
CallTheDoctuh
Sep 2, 2007 09:54 PM
tom kerr
Oct 31, 2006 09:30 PM
Miykl
Merchandise For Sale / Wanted
Oct 1, 2006 10:22 AM
David Shapiro
Aug 7, 2004 11:37 PM
