DB9 cross reference wheel bearing hubs
Old Jun 22, 2025 | 01:43 PM
V12Stealth's Avatar
5 Year Member
V12Stealth
Question DB9 cross reference wheel bearing hubs
Does anyone know of a cross reference for the DB9 wheel bearing hubs 4G43-2B663-AD?
They seem slightly different than the usual source (Lincoln LS, Taurus, S40 etc..)
I was doing brakes on my car when I noticed that the drag on the hubs was quite high. No noise but just very stiff. I suspect they should be changed.
Thanks.
Old Jun 23, 2025 | 11:10 AM
J doubleU's Avatar
That isn't a common issue on these cars, although it's an easy DIY replacement a bit of drag is normal on cartridge bearings. It's when they spin too free is when I would worry, and if they are on their way you will definitely hear them.
Old Jun 23, 2025 | 11:34 AM
V12Stealth's Avatar
5 Year Member
V12Stealth
Thanks for the info. No noise when I spin them by hand. No typical bearing growl.
But I've heard a cyclical metallic squeaking sound when cornering downhill. Not sure if thats related. I'll try to get a bearing in hand to jut feel how much drag there should be.
Old Jun 24, 2025 | 03:20 PM
UltraMarine's Avatar
UltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to all
I've looked for cross referenced wheel hubs before but couldn't get the match. They look very close to a few Motorcraft hubs (like part# HUB352 , 2015+ Mustang), but ours is a bit different.
The other thing is we use large M14 x2.0 wheel studs commonly associated with F-250 SuperDuty, but those have 8 studs. I've looked at JLR as well, where the Jag XE/XF share the hub with the LR platform, just the studs that change from M12 to M14, but still not a match.
Old Jun 24, 2025 | 09:39 PM
V12Stealth's Avatar
5 Year Member
V12Stealth
Were your wheel bearings growling?
Furthest I got was a supplier in Japan with part number HUB032T-15
Old Jun 28, 2025 | 05:54 AM
handyman2009's Avatar
Veteran: Canadian Forces
I also found those in the UK
First Line FBK1329
Just Is
Aug 6, 2021 06:38 AM
gtmule
May 6, 2021 07:42 PM
Pigdog
Feb 19, 2017 04:37 PM
zuman
Sep 3, 2015 08:27 AM
klvnwee
Jul 29, 2011 05:43 AM
