DB9 Rattle Question
Old Jul 27, 2021 | 11:11 AM
Just Is's Avatar
Registered PM
Just Is is infamous around these parts
DB9 Rattle Question
Is anyone familiar with this noise my DB9 makes upon shut down? Seems to be coming from the front of the car. I've seen posts from Bamford Mike and Stuart at Velocity describing the source of some common DB9 rattles, but I am not sure if this is the same sort of rattle they're talking about.
Have any of you dealt with this and if so, what was the fix?
Old Jul 28, 2021 | 03:19 PM
8Tech's Avatar
5 Year Member
8Tech is infamous around these parts
Sorry, can't hear anything abnormal. Could it be the viscous fan slowing down and stopping?
Old Jul 29, 2021 | 11:02 AM
Just Is's Avatar
Registered PM
That's fair, to be honest I had always assumed it was normal til recently. Likely a dumb question, but what fan are you referring to when you say viscous fan?
Thanks for your reply!
Old Jul 29, 2021 | 01:14 PM
J doubleU's Avatar
Electric fans, no coupling?
Old Jul 31, 2021 | 08:01 AM
Just Is's Avatar
Registered PM
Possibly though I distinctly heard the electric fans winding down yesterday without any fuss. This sound occurs the moment I remove the key and the engine shuts off. It's an abrupt and short sound. It's also consistent and sounds exactly the same each time.
I'm hoping to get the car on a lift this week and see what we can find out.
Old Jul 31, 2021 | 08:24 AM
J doubleU's Avatar
Twin electric motors, there is no coupling that would make that noise. There is a mechanical damper on the flywheel that could make a similar noise. Its spring assisted and they like to get rusty and stick together. WD-40 thru a access hole may help the diagnosis.
-James
Old Jul 31, 2021 | 09:34 AM
Just Is's Avatar
Registered PM
Would that be the so-called drive plate? I believe I read that it's common for those springs in the "drive plate" to rattle loose, sometimes due to misfire, but also due to a higher idle which AM then released an update to lower the idle to around 750rpm. I ask because I noticed my idle typically takes around 862 and dips to 750ish on occasion (another issue to look into).
Old Aug 6, 2021 | 06:38 AM
ryanr317's Avatar
ryanr317 is infamous around these parts
Mine makes a similar noise and I believe it's the drive plate rattle based on what I've read from Bamford Rose. I could be wrong, but I though the idle update was to raise, not lower the idle so it would be smoother.
broncoupe
Nov 8, 2021 07:08 AM
gtmule
May 6, 2021 07:42 PM
All Mack
Apr 24, 2017 01:50 PM
telum01
Sep 23, 2016 02:57 PM
speedracer800
Apr 12, 2016 07:05 AM
