Checking diferential and gearbox fluid level
Old Jul 4, 2025 | 05:43 AM
manuel2171s's Avatar
manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s
do you know how to check the level in the differential and gearbox? on a rapide or db9 i guess its the same.
i drove 25000 kms since these were serviced but I want check the level now.I heard many have topped up their differential...
no dipstick for the gearbox on the rapide so you check by removing the plug, if oil comes out of plug its good, if not, stick your finger inside and check how low it is and refill, same for the diferential....
Old Jul 4, 2025 | 12:55 PM
AM-DB9.2's Avatar
AM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of light
Correct for the differential.
When you say gearbox... is that a manual or a ZF6 automatic transmission?
Old Jul 4, 2025 | 03:23 PM
Thanks AM-DB9.2 Its a zf auto.
i m geting ready to do a coolant chnage and battery swap soon.
i am waiting an oak wood beam that hopefully a metal worker will weld walls around and one or 2 other bars so i can use them as jack stands and continue the services. that will allow me to lift the front wheels of 15 cm high. and i may have some of 12 cm high for the rears wheels as when we lift the front are higher than the rear....and lifting the rear upto 15 cm is a challenge i dont like with my floor. anyway it be better than some 6t jack from china. will post images when its done.
Old Jul 4, 2025 | 03:53 PM
AM-DB9.2's Avatar
Aston1936 has a write up that includes how to set/verify the transmission fluid level, the key is the needed fluid temp.
Old Jul 4, 2025 | 04:13 PM
ok yes i ve seen it, thank you, will tryt to do the same when needed with the new oil pan.
cuddapah
Nov 2, 2014 09:58 AM
dan87951
Sep 29, 2014 03:08 PM
flittlejr
Sep 29, 2014 07:59 AM
Wildcat1212
Dec 23, 2013 01:52 PM
Shooter Martin
Aug 15, 2013 05:37 PM
