My 2008 Vantage Progress Thread
Old Oct 23, 2025 | 05:04 PM
sirhodjibob's Avatar
sirhodjibob
Originally Posted by Teekster
not safe to assume that those of us who enjoy a little Roxy Music on occasion won’t wring the neck out of our Astons now and then .
haha!
Originally Posted by embdenb
Looks like Orient blue?
Midnight Blue
Fuel filler lid solenoid replaced
Originally Posted by Gulf_V8V
Awesome project! Hope everything goes smoothly.
My car had low miles and was in perfect condition, but needed a 10 year fluid service, and new tires. So that was around $5k right off the bat. I'll end up doing oil changes from here on out.
Thanks! Yes replacing all fluids is in order. Need to catch up on all the maintenance before the fun stuff.
Originally Posted by MRCW
get you clutch checked. these are notorious for early failures...
also the timing cover gasket
great calls
Clutch operating s intended with no slippage. Will upgrade to a Velocity AP Twin Disc when the time comes. Currently the BMW clownshoe is occupying the workspace, but once I finished intend to inspect the timing cover. I'm sure it's weeping like they all are. Will address that and use that as an opportunity to reseal the engine.
Originally Posted by PC-V8V
Congrats on the new Vantage! Beautiful spec on that one!
Thank you!
Old Nov 1, 2025 | 04:03 PM
sirhodjibob
Did a quick one step polish with Sonax Perfect Finish + Avalon King ceramic coat. Came out nice, paint is in nice shape. Thought about pulling the PPF on the rear side sills, but left as I may change up to V12 side skirts in the future.
Old Nov 1, 2025 | 05:00 PM
sirhodjibob
This should keep me busy for a little bit
Yes missing a rear brake rotor and 6 spark plugs...the joys of international shipping.
Old Nov 8, 2025 | 03:16 PM
sirhodjibob
Purchased a set of N24/GT4 OZ Magnesium wheels from a local Aston owner. These had been kept in storage for years with no tires ever mounted, manufactured in 2008. Plan is refinish these in silver which I think will suit the car better.
These are 18x10 +45 front, 18x11 +48 rear.
Old Nov 8, 2025 | 03:36 PM
IJWS's Avatar
IJWS is a jewel in the roughIJWS is a jewel in the roughIJWS is a jewel in the rough
LOVE those OZ wheels!
Old Nov 8, 2025 | 03:41 PM
PC-V8V's Avatar
PC-V8V is infamous around these partsPC-V8V is infamous around these parts
What a find! I'd bet there aren't too many completely fresh sets out there anymore. Those will look very nice.
Old Nov 8, 2025 | 04:26 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Welcome and enjoy your Aston Martin.
Old Nov 9, 2025 | 01:23 AM
sirhodjibob
Thanks! Yes super lucky find on the wheels, especially only an hour's drive from my house. Will of course have upcoming aesthetic modifications that compliment the wheels.
Back to less fun stuff:
throttle body cleaned, new gasket. Wasn't dirty at all really.
OE vs blueprint filter. I purchased some GT4 style airbox delete brackets, but held off installing after seeing the all the effort in the OE ducting. I'm just after induction noise, is it worth it?
Last but not least here's that pesky timing cover. Leaky, but not leaving drips on the garage floor. No photo but it's leaking a bit higher up as well, likely the "T" junction. Annoying for sure, but it can wait a little bit and I gave it a good clean for now. For what it's worth the cam cover seals don't appear to be even weeping a bit.
Old Nov 12, 2025 | 03:42 PM
Distwo's Avatar
Distwo is infamous around these parts
If you do replace the timing cover seals, can you take detail step by step pictures? I'll probably have to get to it at some point but I'd like to see if there's anything harder than expected on the vantage. Thanks!!
Old Nov 12, 2025 | 03:44 PM
Distwo's Avatar
Actually... A quick G search gave me what I was looking for and it does look pretty involved https://bernardembden.com/am/timingcover/index.htm
Old Nov 13, 2025 | 08:49 AM
sirhodjibob
Yes I certainly can. I have replaced the timing chain cover gasket and guides on my M3, and this doesn't look fundamentally much different besides the extra headache on working on a V shaped engine vs an inline one. I already have an engine support brace. That said my spare time to be working on cars is much less these days.
I suppose the other item to keep in mind is that you can not simply swap on a new gasket, the cover itself needs to be checked for straightness.
Old Nov 14, 2025 | 04:07 PM
VantageAston's Avatar
VantageAston is infamous around these parts
I have bad new for you in that it is most definitely fundamentally different.
Changing the timing cover is an Engine-out job, at least 15 hours work for a pro shop, longer for a DIY'er. Do not attempt to do the cover with the gnine in the car, you end up having to remove so much from the engine it actually takes longer than taking the engine out.
Here's a video explaining but the good news is, there's really no need to replace it unless it's a major leak, and you look like you have minor weeping at most. He even states not to use an engine brace.
Old Nov 18, 2025 | 04:11 PM
TonyN923's Avatar
TonyN923 is a jewel in the roughTonyN923 is a jewel in the roughTonyN923 is a jewel in the roughTonyN923 is a jewel in the rough
I would even worry about the front cover plate, people have replaced the seals and it leaks seeps again. If its not dripping, just wipe it clean when you change the oil and call it a day.
Old Nov 21, 2025 | 09:49 PM
sirhodjibob
https://www.youtube.com/watch?v=4tYLcq0VJNI
It's not, you clearly have no experience here. The major issue for a DIY job is potentially seized front subframe bolts- a far less likely scenario for fair weather driven cars in the United States.
The major advantage for DIY to me is not cost savings, but rather to be more thorough than any shop would. Is a shop going to take time to vapor blast the front cover? Replace each nut and bolt with new (and deal with wait time of ordering all these)? Replace all the coolant hoses and fixings along the way? Probably not. Even some dealers replace it with engine in, although if I had the space, I certainly would choose to remove.
True
Relevant:
Old Nov 21, 2025 | 10:15 PM
sirhodjibob
Anyways, the maintenance reset continues. Oil and transaxle fluid changed.
Installed:
Motul 10W-60 oil
9G33-6714-AA - oil filter
6G43-04-10082 - drain plug
6G33-9N228-AA - drain plug washer
6G33-6C861-AA x 2 oil bypass filter o rings
Redline MT-LV transaxle fluid
4G43-27-10491 - transaxle filter o ring
4G43-27-10245 x 2- transaxle drain & fill plug washer
Drain & fill plug torqued to 49nm.
Only made a minor mess. Took about 4.5 quarts or so. The fluid in there was fortunately super clean, but likely original. Note- I did NOT empty the cooler lines, per the member on here from Velocity AP's advice.
Don't forget the transaxle filter o ring:
Much more fun and interesting parts (from Poland!) on the way, just need to keep powering through on the maintenance stuff a little longer.
