Converting V12S paddle shift to 6 speed manual... Advice?
Old Nov 30, 2025 | 07:31 PM
valor1's Avatar
5 Year Member
valor1 is infamous around these parts
They've since closed the UK office where I contacted them.
Old Nov 30, 2025 | 08:20 PM
Stuart Miller's Avatar
Stuart Miller
Thanks for the reply - I thought that might be the case.
Old Nov 30, 2025 | 09:09 PM
valor1's Avatar
5 Year Member
You're welcome.
Old Dec 1, 2025 | 05:10 PM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
The CCF has a couple settings related to the gearbox type. At the minimum this will need to be changed in the CEM. It's possible the CEM and PCM may also need to be re-flashed by AMDS after the modified CCF is flashed. I've seen AMDS fail to flash some settings and even if the CCF is modified AMDS may not flash the manual box supporting software. Not sure if it has an as-built database of the supported cars that it checks against or not. It's also possible there's some other part of the config I haven't decoded yet. I haven't done anything as ambitious as a manual swap, mainly only infotainment mods. Not for lack of want... The DB9 is my SO's car and she insists on keeping the auto box.
3-DB-GEARBOX=
0x00;Undefined;
0x01;Manual AML; <-- this
0x04;Auto or ASM;
4-DF-GEARBOX,TYPE=
0x00;Undefined;
0x02;Auto VH1/ASM VH2 >=VH400 ZF 6 Speed Auto Only;
0x03;ASM 6 Speed;
0x04;ASM 7 Speed;
32-DC-NEUTRAL CONTROL AUTO.GEAR=
0x00;Undefined;
0x01;Default AML; <-- maybe this
42-DG-STARTINHIBITOR MANUAL GEAR BOX=
0x00;Undefined;
Old Dec 1, 2025 | 10:36 PM
valor1's Avatar
5 Year Member
3-DB-GEARBOX=
0x00;Undefined;
0x04;Auto or ASM;
4-DF-GEARBOX,TYPE=
0x00;Undefined;
0x03;ASM 6 Speed;
0x04;ASM 7 Speed;
0x00;Undefined;
0x00;Undefined;
So do you do this sort of ECU tuning / can you do this sort of ECU tuning?
Old Dec 2, 2025 | 07:13 AM
GA_DB9's Avatar
5 Year Member
I have only dabbled in changing the config of my car with my personal AMDS. I haven't done any ECU tuning in the classical sense.
GhostRider59
Dec 8, 2025 11:47 AM
certified_prime
Feb 19, 2013 03:46 PM
P-Gunna
Apr 26, 2012 04:55 PM
MK23
Feb 8, 2012 01:25 PM
despine
Lamborghini
10
Dec 21, 2010 10:34 PM
