Throttle Body Sensor Connector Replacement - V12 DBS
Old Jan 15, 2026 | 07:41 PM
BrockDBS's Avatar
BrockDBS
Anybody replaced the connector on the throttle body wiring harness? Source for new pigtail? Kindly advise. The outer casing with mine on the passenger side cracked and needs replacing. Thanks so much in advance for any guidance.
Old Jan 16, 2026 | 11:43 AM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
As far as I recall, the throttle body is a standard 68mm Bosch unit... at least on the DB9. Not sure if the DBS uses a different one on its V12.
If it's the same it should be something like this, but disconnect and verify yours. I can't get at mine right now.
www . efihardware . com/products/3026/bosch-dbw-throttle-body-6-pin-connector
Old Jan 16, 2026 | 06:49 PM
BrockDBS's Avatar
BrockDBS
You are correct, Sir - thank you! Here it is at Summit and appears same part, though not a Bosch manufactured part:
https://www.summitracing.com/parts/hth-ht-030432
BrockDBS
Nov 16, 2025 09:41 PM
y2kgixxer
Oct 30, 2023 09:57 PM
compositeguy
Cayenne 955/957
Nov 29, 2016 10:58 PM
Mk996tt
Oct 15, 2013 09:00 PM
mbagge01
Cayenne 955/957
Nov 11, 2012 04:01 PM
