Sponsored By:
Sponsored By:
'06 S4 First gear engagement problems
Old Jan 4, 2008 | 07:09 PM
RocC4S's Avatar
RocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant future
What's up guys... My brother in law owns the car. He finds it very difficult to put the car into first gear after sitting at a stoplight in neutral, have to push very hard to engage.
He took it to the dealer and they called it normal. The shop foreman said the earlier S4's had poor syncros and therefore Audi was replacing a lot of gearboxes. To alleviate this problem, Audi re-designed it to have more square cuts gears but now is a handful to put into 1st and 2nd.
My question is, does anyone else have this "normal" problem or does this seem like a bunch of BS and they don't want to fix the car.
Thanks ahead of time, Roc
Old Jan 4, 2008 | 08:08 PM
Arnie's Avatar
Arnie is infamous around these parts
I have a 06 S4 and it is as smooth as butter shifting into first and all the gears. Try and drive another 06 and compare and see who is right. Mine is fine
Arnie
Old Jan 4, 2008 | 09:52 PM
PARealtor's Avatar
PARealtor is infamous around these parts
only time I have issues getting it into gear in during very cold mornings... once its warmed up its fine.
Old Jan 5, 2008 | 09:28 AM
Dan's Avatar
Dan
Dan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to beholdDan is a splendid one to behold
Steve Kojasevic mentioned in his post that he has a similar problem. BUT he did also mention that this problem should be covered under warranty. Why don't you try talking to him to get some more insight.
Old Jan 5, 2008 | 10:59 AM
RocC4S's Avatar
So it seems the general con-census is that the dealer is probably not interested in pursuing further, correct? I don't think it's right...
The car is still under warranty so it seems like a no brainer to me
Old Jan 5, 2008 | 08:00 PM
lmmikes4's Avatar
lmmikes4 is infamous around these parts
I had the same problem with my '05 when it was new. It was some kind of alignment with the shifter or shift gate. It was a simple fix, they just re-aligned the shifter. I'm not that mechanical, so I don't remember exactly. My dealer fixed it under warranty.
jaehoppa
Oct 22, 2015 09:17 PM
georgemaser
Oct 17, 2015 05:59 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
GSP
Sep 9, 2015 05:31 AM
andbos
Sep 7, 2015 07:13 PM
