Sponsored By:
Sponsored By:
RS4 emblem all-weather rubber floor mats, do they exist?
Old Nov 8, 2008 | 12:13 PM
RocC4S's Avatar
RocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant future
Can't seem to find any, have you?
All I can find are mats with the Sport logo /oooo/
Old Nov 10, 2008 | 02:55 AM
Teutonic_Tamer's Avatar
Teutonic_Tamer is infamous around these parts
The only "official" Audi supplied rubber mats are just the generic ones, which fit all B7 variants (A4, S4, RS4).
And I haven't heard of any aftermarket rubber mats with an RS4 logo in them. I suppose rubber floor mats just arn't seen as "sexy" when it comes to making custom bits.
Maybe someone like www.JustMatz.co.uk might be able to help, or point you in the right direction.
Old Nov 10, 2008 | 10:36 AM
Jorgeassoc's Avatar
Jorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant futureJorgeassoc has a brilliant future
i want to know where i can find floormats also.
Old Nov 10, 2008 | 04:34 PM
sanjay's Avatar
sanjay is a jewel in the roughsanjay is a jewel in the roughsanjay is a jewel in the rough
while they don't make a monster mat (that's the correct term) mat which says RS4 like the A4/A3, etc ones....the audi sport ones is what i use
they fit perfectly and look amazing
i leave them in all year around
Old Nov 10, 2008 | 08:48 PM
RocC4S's Avatar
Where did you get them?
Old Nov 11, 2008 | 06:55 AM
sanjay's Avatar
the dealer sells them
just ask for the 'b7 audisport monster mats'
they're a little expensive (around $90 but worth every penny) they look amazing in the rs4
i'm sure you could email an audiparts place online if you're lazy like me
mike@purems.com has been good to me
Old Nov 11, 2008 | 09:38 AM
Jorgeassoc's Avatar
im calling my local audi dealership right now.
Old Dec 10, 2008 | 07:35 AM
txlef's Avatar
txlef is infamous around these parts
Not for B7?
According to my local dealers (Paul Miller and DCH) the Audi Sport rubber floor mats ("Monster Mats") are NOT available for the B7. I have them in my B5 S4, but the only rubber mats available that fit my B7 RS4 (according to the dealers) are the generic black ones with no emblem. Any other ideas? I really want to get something in the car before the snow.
Old Dec 10, 2008 | 07:58 AM
DAP's Avatar
DAP
DAP is infamous around these parts
From some searching on Audiworld, the Audisport mats for the B6 and B7 are the same (i.e., they fit 02-08 A4/S4/RS4). So you should be fine ordering those for the RS4.
Old Dec 10, 2008 | 08:24 AM
txlef's Avatar
Thanks, Dave. Just ordered them. Tell Tony Lou says "Hi." And how come my O2 sensors keep burning out??
Old Dec 10, 2008 | 09:21 AM
DAP's Avatar
DAP
Which sensors? Primary or secondary? How often are they failing? What are the mods on the car?
Old Dec 10, 2008 | 09:40 AM
txlef's Avatar
Bank 2, Sensor 2. Replaced it twice in the past 3 weeks. Actually, the sensor isn't burned out (checked it in another S4), but I'm getting no signal. Checked resistance and it's fine. Checked power from ECU and it's fine. Power is getting to the O2 sensor. Everything seems to check out, but I keep getting P1140 (Bank 2 Sensor 2 Internal Resistance Too Large) and P0160 (Bank 2 Sensor 2 No Activity). I get fluctuating numbers when I VAG it; so I know it's reading. I have checked out this sensor (and two others) in another S4 and it's fine. The only thing I can think might be the problem is the ECU; otherwise how can I be getting those codes when VAG says it's reading? Tony did all the tuning. I'm stumped and can't get an inspection sticker.
Old Dec 10, 2008 | 09:46 AM
DAP's Avatar
DAP
Hmmm... if there's not a short in the wiring somewhere, it might be a faulty ECU. Its definitely nothing related to the tune... but the hardware of the ECU could be bad.
Do you have any other S4s in your area that could swap ECUs with you (if your car is a Stage 3, then it would have to be another Stage 3 car with the same fuel injectors)?
Old Dec 10, 2008 | 09:49 AM
txlef's Avatar
Nobody around here has the same injectors. My mechanic is calling Tony today to talk about it some more. I may have to come back up there.
Old Dec 10, 2008 | 10:24 AM
Those "standard" rubber mats work just fine in the B7 RS4 - I have them in mine. They arn't quite as "chunky" as those in the picture earlier in the thread - but they are a little more subtle in design - with embossed triangles, and a lip around the edges of about 5mm.
I've never had any snow or rain puddles beating the lip.
For those who have the steering wheel on the wrong side (on the left! ) - here are the official Audi part numbers for the rubber mats:
  • 8E1 061 225 041 - rubber mats, set of 4 (front and rear), satin black
  • 8E1 061 501 A 041 - rubber mats, set of 2 (fronts), satin black
  • 8E1 061 501 A 528 - rubber mats, set of 2 (fronts), medium grey
  • 8E0 061 511 041 - rubber mats, set of 2 (rears), satin black
  • 8E0 061 511 528 - rubber mats, set of 2 (rears), medium grey
HTH
