Sponsored By:
Sponsored By:
Help - Is this normal?
Old Feb 15, 2005 | 09:05 PM
Kraftwerk's Avatar
3.6TT/2 = 1.8T
Kraftwerk is infamous around these partsKraftwerk is infamous around these parts
So I went for a quick blast on the way home from dropping off my brother. Hit well over 100 mph on a couple occasions but entire adventure didnt last more than 5 min. Take into consideration that I was at WOT a couple of times. Check out the red hot turbo, I know that some heating is normal but is this NORMAL?!?!? I've noticed it much in the past too...
Zoomed out view.
Old Feb 15, 2005 | 09:40 PM
schnellerm3's Avatar
schnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant futureschnellerm3 has a brilliant future
Yes, that's normal, just let your car run for a minute or so after hard driving...
Old Feb 15, 2005 | 10:15 PM
Kraftwerk's Avatar
3.6TT/2 = 1.8T
Thanks for helping GoWide. And yes I did that, I usually let it cool down 3-5 min after spirited driving. I need a turbo timer.
Old Feb 19, 2005 | 06:52 PM
JonA4's Avatar
JonA4 is infamous around these parts
Well, I just noticed the same thing, but mine glow more of an orange color, and you can only really see it when its dark outside. I was going a steady 180kph for about 3 minutes, and they were just glowing!
Old Feb 21, 2005 | 12:37 PM
Kraftwerk's Avatar
3.6TT/2 = 1.8T
Jon - It's normally orangeish red but after a few minutes at full throttle in 4th and 5th gear, with the turbo working double time it turned a pinker shade. And yes it tends to be only visible at night, I just didn't know if it was bad for the turbo or not to be continuously that hot for a good amount of time.
Old Feb 26, 2005 | 11:55 AM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
Yes thats actually very normal
Turbo's run most efficiently when they are glowing......
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
Highlander
Dec 21, 2015 08:42 PM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
fanporsche
Sep 30, 2015 02:26 PM
