Window regulator fun...
Old Sep 27, 2015 | 02:27 PM
Highlander's Avatar
Highlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond reputeHighlander has a reputation beyond repute
...and by fun, I mean frustration!
All of the documentation I could find online shows 996.542.076.04 as the correct part # for the passenger side regulator on my '02 TT Coupe.
So I bought this OEM Porsche part
When I removed the old regulator. It has a different part number. Similar, but different:
996.542.016.04
I went ahead and installed the 996.542.076.04 regulator, but the window won't go all the way down into the door.
Is this normal? The driver's window drops down all the way so there is nothing visible. I don't normally drive with my windows down and can't remember if this is how it should be.
Am I missing something? Is there an adjustment I can use to fix this?
Old Sep 27, 2015 | 02:34 PM
BLKMGK's Avatar
Did you have power removed when you did the job? Removed from the whole car? When you lose power you have to "train" the windows for full up and down operation. If you didn't remove power it might be possible that it's still somehow trained to stop but in the wrong place? Just make sure you have radio codes etc. if you're going to remove power and try to retrain blah blah.
A friend just bought regulators for his car for both sides, I'll see if I can get him to post what he used...
Old Sep 27, 2015 | 02:48 PM
Highlander's Avatar
Yes I disconnected the battery. You have to remove the airbag and those things scare the **** out of me. I always have no power to the car when messing with those!
I have not put the door back together so I can see inside. You can see that the regulator is all the way down as far as it will go.
Old Sep 27, 2015 | 05:00 PM
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
These regulators are shared with the Boxster. Did you catch the part of the install where you need to remove the upper boxster specific stop? Likely why it's not going all the way down in your install.
Old Sep 27, 2015 | 05:15 PM
Highlander's Avatar
ding, ding, ding, we have a winner.
Now you mention the stop, I can see there are two stops. An upper and lower stop.
There is no upper stop on the regulator I removed - Doh!
Thanks for the help. This forum (and more importantly, the people on it) rocks!
Old Nov 26, 2015 | 06:39 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
How did you resolve the problem? I need to replace the same part on my 02.
Any tips for a first timer?
Old Nov 26, 2015 | 12:52 PM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
The best tip I have is don't buy the Chinese ones! I bought one and installed it. It rolled up significantly slower than the other OEM. I sent it back and did a used OEM unit,
Old Nov 26, 2015 | 04:16 PM
'02996ttx50's Avatar
?! a what? a chinese window reg? really...?! oh man.. whats next. sheesh.
Old Nov 26, 2015 | 10:26 PM
pumptech's Avatar
Most of the ones you see on eBay are Chinese aftermarket.
Chinese con rods??!!?? Anyone??
Old Nov 27, 2015 | 05:35 AM
Scawt's Avatar
Scawt is just really niceScawt is just really niceScawt is just really niceScawt is just really nice
I have extra OEM TT window parts if anybody needs them.
Old Nov 27, 2015 | 07:01 AM
oh, you mean xian less yaun pauter!? lol. got it!
Old Nov 27, 2015 | 09:07 AM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
I need the driver's side microswitch that lowers the window slightly when I open the door from inside the car - at least I think I do. Have that part?
Old Nov 27, 2015 | 02:01 PM
pumptech's Avatar
Iv got both side regulators, motors, micro switches and then some as well.
Old Dec 6, 2015 | 08:43 PM
Vantaredoc's Avatar
Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !Vantaredoc Is a GOD !
I could use a good working right side regulator as well as the yellow led behind the passenger inside door handle. I installed a regulator from Amazon and it sucks. I installed a factory Porsche on drivers side and it drops twice as much when opening and closing door.
Old Dec 6, 2015 | 09:09 PM
pumptech's Avatar
I sold my passenger side regulator on eBay last week. Not sure about the LED light. Is that part of the micro switch?
