Sponsored By:
Sponsored By:
stolen car found/damaged/what should I look for???
Old Mar 9, 2012 | 02:16 PM
  #31
sakimano's Avatar
sakimano is infamous around these partssakimano is infamous around these parts
Originally Posted by SEXICÄN
Well if your in the market soon for another Audi I know a Audi Sales person out side of your state*
*me
wrong country...and Audi would probably get a real kick out of you trying to sell cars to non-residents lol
Old Mar 10, 2012 | 06:42 AM
  #32
black penguin's Avatar
black penguin has a brilliant futureblack penguin has a brilliant futureblack penguin has a brilliant futureblack penguin has a brilliant futureblack penguin has a brilliant futureblack penguin has a brilliant futureblack penguin has a brilliant futureblack penguin has a brilliant futureblack penguin has a brilliant futureblack penguin has a brilliant futureblack penguin has a brilliant future
So, here's an update:
The car has now been written off by the insurance company. It is now a "Total Loss".
If you don't have the Full Replacement Value clause in your coverage, I would suggest you get it. The damage to my car, MAY have been deemed repairable otherwise.
*** Here is the letter I sent stating my case. This was considered a well articulated argument. It might be helpful to someone down the line when assessing the true damage to your car. I could find hardly any help online, and I'm sure the insurance companies have terabytes of data when assessing you***
>>> Dear, XXXXX
The car in question is a rare 2012 Audi TT RS.*
These cars have been created in low numbers for the enthusiast market. The RS cars from Audi are collectable and are NOT AVAIBLE at every Audi dealer. All cars have been pre-purchased by the dealers lucky enough to get an allotment. Come the end of this month the supply will likely dry up and the available cars will sell at a premium above what I paid.*
This is a car purchased by people who know cars, they buy this model for the engine.*
This is a high performance car that must be safe up to the 155 mph speed limiter (even though that is not possible/advisable/legal on public streets. An owner COULD, choose to do this on a private course)?*
The car was stolen from my driveway after ten days of ownership. Just ten days old, so the car was in showroom condition. A special car so I purchased FULL REPLACEMENT VALUE.
The thief had a key. You have all of the keys, I was given. I never had the key he apparently used, nor have I seen it.
Damage appears to include, but is not limited to the following:
The front driver fender, spoiler hood etc have sustained damage and will need to be replaced.
The drivers front wheel has been pushed back due to a bent control arm. This is a hard hit to the front wheel drivetrain.*
The frame will have to be measured to ensure it has not been compromised in anyway from the two accidents. It is an 69% aluminum car so the frame is a concern.*
The tow truck driver apparently did not use proper protocol while removing the car from the ditch. These cars should be "Flat bedded" to avoid any drivetrain damage. A detailed review of the drivetrain will be required.*
The THIEF stole a manual transmission car. The gears and clutch (haldex unit and two differentials) will require a visual inspection to ensure there has been no abuse, or use that could create a future issue or reduced performance. The clutch and brake pads will have to be replaced as they are wear items.
The brand new paint has been covered in finger print dust and dirt. This surface will have to be returned to showroom condition. This includes swirls, scratches, stone chips etc.*
The interior has been abused and is filthy. It smelled of smoke (all residue must be removed from fibers etc) and there is good reason to believe the car has been used for drugs. Please be sure canine units will not flag the car when i travel across the border. It appears they "Lived" in the car.*
The passenger seat is broken and must be replaced. Please be sure all other hinges etc are not also abused.*
The car has substantial mileage put on it since I owned the car. I had XXX miles, it now reads XXXX miles. That's equivalent to distance from Toronto to Miami. To put it another way, that is close to six months of driving for me (check my Audi service records).
This mileage is 3.64 times what was on it before. Judging from the state of the car this was not a joy ride around the block. Not all miles are equal.
To make matters worse, this mileage was put on during the critical break in period. The engine is a high output turbocharged 5 cylinder, it needs to be driven according to a specific break-in schedule. The restrictions are severe, here are a few examples:
No full throttle
Vary the engine speeds and keep revs below 4000 rpm
Do not keep the car at the same rpm for more than 10 mins. On highway shift between 4/5/6th
Do not exceed 2/3 of maximum rpm (much lower threshold than a fault code would record)
Do not rev the engine up to high rpms when the engine is cold
Don't slip clutch, don't dump clutch etc
Many of these restrictions are far below the Audi fault code threshold, so there is no way of proving they have been adhered to.*
If you choose to review the ECU for a history of the miles he put on the car, you will likely see all the proof I need. But, there are many forms of abuse they wont show (clutch dumps, improper cold reving, improper cool down, constant rps, etc), so it's not conclusive.
Many consumers claim their cars are "just like new", but my car was new, just ten days old. Every component was factory perfect (less XX miles). The excessive additional mileage put on irresponsibly during the break-in period means the car cannot be returned to the condition it was in before it was stolen. Therefore I am asking that I receive a new car with mileage equal to or less than XXX miles and a value of $XX,XXX+. This is what every average consumer would expect after paying for the Full Replacement Value Coverage.*
I expect to hear your response by XXX Xth. I am hopeful you will agree and we can continue our business arrangement. Should you choose not to, we will have to move straight to the Ombudsman stage
Old Mar 10, 2012 | 06:52 AM
  #33
Originally Posted by sakimano
that sucks. Hopefully it gets totalled out.
p.s. any thoughts about having a mod add this posting to your 'car stolen after 12 days' thread? Would have been a nice resolution to that story for those who read it.
https://www.6speedonline.com/forums/audi/268557-tt-rs-stolen-after-12-days-if-ownership.html
I'm good with that. There is surprisingly little info out there that is helpful. Whatever helps the next guy is fine by me.
What kind of Programing" do you do?
Old Mar 10, 2012 | 08:56 PM
  #34
SEXICÄN's Avatar
SEXICÄN is infamous around these parts
Glad you got everything settled! I hate dealing with insurance since they never want to pay, but know they have to to keep you as a client.... I wish I was a insurance company, they make BANK@!!!!!
Old Mar 13, 2012 | 12:09 PM
  #35
casper's Avatar
casper is just really nicecasper is just really nicecasper is just really nicecasper is just really nicecasper is just really nice
wow great letter to your insurance company. glad everything worked out for you. make sure you post new pictures of your tt rs
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 09:56 AM
