JIC Cross Suspension for 996 C2, C4 CHEAP
Old Jan 31, 2005 | 11:46 AM
RWDRIFTC2's Avatar
RWDRIFTC2 is infamous around these parts
Selling the JIC Cross Suspension out of my 996 C2 and C4 for Cheap. These are the medium spring rates with 8k/12kg. Comes with camber adjustable upper mounts, helper spring, ride height adjustment bracket with 15 way damping adjustablity, and sway bar bracket. $1400
Old Jan 31, 2005 | 03:00 PM
Ruiner's Avatar
How did you enjoy the ride? Too rough? Perfect?
Old Jan 31, 2005 | 08:03 PM
RWDRIFTC2's Avatar
Depends on which stiffness settings you have it on. The upper pillow mounts make for a stiffer ride, but if you decrease the stiffness on the shock its fine. I took it out because I just put a custom fiberglassed system in the trunk.
Old Feb 4, 2005 | 01:05 PM
RWDRIFTC2's Avatar
Found out this is only for Carrera C2 right now. I am going to do more research.
Old Feb 4, 2005 | 05:16 PM
Bobby G's Avatar
Bobby G is infamous around these parts
Vince - if you bought the C2 version, then you'll need the droplinks to fit a C4. I know from experience.
-Bg
Old Feb 9, 2005 | 10:08 PM
RWDRIFTC2's Avatar
How much are the drop links?? So right now it looks like they will fit only C2.
Old Feb 10, 2005 | 07:16 AM
Chads996's Avatar
Chads996 is infamous around these parts
RWDRIFTC2 - You have a PM.
Chad
Old Feb 10, 2005 | 07:30 AM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
if u buy th jic's call jic to getteh softetst spring setting it's like 50 bucks i think it'll make your ride a little bit better it thinkit's the 8k/10kg spring setting it's for the soft/street set up
Old Feb 10, 2005 | 05:00 PM
RWDRIFTC2's Avatar
Chad
You Got Mail !!!
Jul 29, 2019 11:13 AM
97GtsMonster
Nov 17, 2015 12:38 PM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
