Highly Modified 964 DE/Steet
Year: 1990
Make: Porsche
Model: 911
Price: $42500
Mileage: 27000
Color: GP White
Location (State): CT
Transmission: Manual
Drivetrain: Rear Wheel Drive
94 authentic 3.6T engine & G50/52 Turbo driveline 26k miles Stock internals, never opened
94 3.6T complete suspension, and sub frame 26k miles Done as from factory
94 3.6T Big Reds, hubs Rotors, carriers 26k miles
All 3.6 Turbo parts from my orig 94 3.6T with 19 k miles used as a doner, meticulously maintained history.
Wheels
Speed line wheels 18X8s 18X10s Genuine Coarse not etched
Carrera 5 spoke powedercoated Glossy blackW/logo caps 18X8s 18X10s Very light and strong
Modifications Done have less than 5k miles
Wide body conversion to Factory specs All OEM 3.6 Turbo trailing arms and sub frame parts
Conversion included origonal fenders never removed Fiberglass flares by Betterbodies added
and respray with OEM color
BetterBodies bumpers and wing Side rockers OEM 3.6T urethane
Airducts Carbon fiber bumper mounted and aids in brake cooling
GT2 rear spoiler W/CF wing effective and adjustable
HID h4 headights W/high beam 5500 kelvin super bright
EFI conversion very conservative tune 4k miles runs very cool on track lots of low end torque
Haltech EV11V2 ECU 2 program Very advanced with conservative tune
55llb low impedance injectors smooth idle and qwick response
ITS custom T-4 Turbo Qwick spool very linear/no lag
Pat williams fuel rails utilizes stock 965 manifold
Custom air intake w/kN very unrestrictve
RS single belt fan and alternator pulley A/C compressor removed can be reinstalled
3.6T AC compressor removed If reinstalled AC works
MSD ignitionW/ tach module works with stock tack /multiple spark
GHL headers w/heat with oil line kit/ no CAT
B&B muffler w/WG pipe no CAT/ quiet and throaty
Tial 46mm waste gate 7lb spring
Blownsix IC 965 65% bigger than OEM Easily passes Emmission test
LW RS Fly Wheel /w/Sachs stg 2 clutch all new parts from IA
Suspension
JIC cross /Magic coilovers( new front dampers) 10 &14 kg program w/14 adjustments
ERP front and rear monoball bushings Control arms & trailing arms
ERP rear spring plates allows for more neg camber and toe
TRG adjustable swayRear w/ RS droplnks Front drop links are Porsche Motorsports
TRG adjustable swayRear w/custom droplnks rear
Red line front strut brace Alum and Stainless
lowered to RS spec ,alighment ,,Corner balanced Set up By Dan Jacobs
Awsome Stopping Brakes
993 Master cyl and vac booster 22 mm bore for 3.6T OEM big reds
stainless brake lines w/Turbo bias valve ATE blue fluid
Performance Friction brake pads 97 race compound
Interior
GT3 Euro type seats Cabon fiber, Alcandra cushions,very light,tight and comfortable
DAS roll bar powder coated/Approved
simpson 5 point harnesses dated ok for DE
Fire extingisher mounted on DAS roll Bar
Momo racing wheel w/quick disconnect Quick steering horn works auto self centering
Tru boost electronic boost controller easy to use /2 programs
AEM shift light LED w/ hi low levels
NGK wideband Air/fuel ratio meter very accurate and easy to read
Haltech Trim module Allows you to control fuelmixture on the fly
Oil cooler switch Allows for very cool runningin traffic or on track
renline floor board allows good foot work on track
renline pedals allows good foot work on track
Alum diamond plate mats allows good foot work on track
Dash mounted Kill switch Saftey and security
Power windows and Oem door panels, carpet in place Could be removed and reduce 300 lbs of weight
Oil changed very frequentl
no oil leaks
Labor to install above
The mechanicals have been meticulously maintained and car is always garged and has little use. and car is always garged and has little use.
This car is significantly detuned for DE/and street and has potential to be GT1 racer with very little work.
It is very Fast,Safe, Solid and fun to drive.......... A GT3 killer
Sadly must sell
Sacrifice at $42,500 OBO
Hi there,
I have 3 Pcars right now . ....That said what do you have to trade?
Elliot
Elliot
im looking for a turbo, basically 3.6
since that seems to be a bit tough at the moment, im looking into alternatives.
kindly send me pics on aziz.sinno@gmail.com
Cheers,
If you are interested I can put you in touch with the dealer ( very reputable )
Email me
Elliot
weblight@snet.net
Email me
Elliot
weblight@snet.net
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Vendor Classifieds
Aug 18, 2015 03:55 PM
PelicanParts.com
993 Turbo Vendor Classifieds
