Fully built Hellion TT 4R70W Cobra, 1000 RWHP
Old May 9, 2012 | 08:27 AM
2bscrewed's Avatar
2bscrewed is infamous around these parts
Year: 2003
Make: Ford
Model: Mustang Cobra
Price: $28000
Mileage: 40000
Color: Black
Location (State): VA
Transmission: Automatic
Drivetrain: Rear Wheel Drive
I'm really on the fence about it because I know I can't get anywhere near the amount of money I have in it in mods alone, but I haven't really done anything but work on the car in years, and the family isn't really interested in it since we all started riding ATV's a lot this past year. If I sold it I could afford to get a better tow vehicle (something at least 3/4 ton with a 3rd row seat) for the toy hauler and a big 4x4 quad that I want, and I think I would get a lot more use out of them, then I do the Cobra.
A lot of you know the car, but the basics are:
Built Teksid short block by Fox Lake 9.1-1 Diamond Pistons, Oliver rods, Cobra Crank.
Built 4R70W by Darrin at BC Automotive with manual Valve body and L/U and O/D on a switch and Hurst pistol Grip 1/4 stick.
Solid axle with lots of reinforcement with Moser 31 spline axles and True Track diff
Full Lethal Returnless fuels system with 3 GT pumps, MDM, and 80# injectors
Cooling mist Meth kit
Red Alert EGT system with sensors in every exhaust port set to kill the boost controller upon any cyl lean condition.
Eboost 2 boost controller
Hellion TT kit with custom 3.5" intake tube powder coated to match the valve covers and 01 Cobra intake.
Full UPR tubular front suspension
Strange struts/shocks
Powder coated 17" Enkei RPF-1's (15 #'s and 17#'s)
Corbeau CR1's with a Bolt in MM 6 point roll bar with swing outs and removable harness bar that is also powder coated black
Thats' just the big stuff, there are obviously a ton of other parts I'm not even mentioning.
The car made 700 on straight pump and 16.5 #'s, 850 on pump/meth and 23#'s and 991 on race gas and 28#'s through the T-56. I've only dynoed it on the pump Meth tune since putting the auto in and it made 780. Believe me when I say that now that the converter is loosened up, it feels Waaaaay faster with the auto.
The body is in good shape, but it is black, and does have some small rock chips and scratches that you only see because the car is black, but it looks good for a car that has been driven and has just turned 40k miles.
The car also came in 3rd in the 2010 5.0 Mustang and Super Fords Magazine King of the Street competition, and you can also look up my screen name and see everything good and bad the car has ever done.
I tried to build the car to run 9's in street trim and be able to be driven anywhere, and it should have no problems doing that now that the converter is set up right.
If I can't get close to $28k for it, I will probably just keep it. But if someone wants a nasty, evil looking Cobra to scare the **** out of themselves with, this is the one for you, and it will save you about $30k instead of building it yourself.
The car just hit 40k miles and I have the clean title. Almost all of the mods have less than 2k miles on them.
Here is a more complete mod list.
98 Cobra Teksid block .020 over
Cobra crank
Oliver Billet rods
Diamond 11.5cc pistons
Stage II ported heads
Livernois springs
Modular performance Custom turbo cams
Head cooling mod
Livernois oil drainback kit
Canton windage tray
Melling high volume oil pump
98 Cobra timing cover
ATI Super Damper balancer
Ported long runner 01 Cobra intake
Sullivan fuel rails
80# injectors
Lethal performance returnless fuel system
Fore Triple fuel hat
3 Ford GT fuel pumps
Zone 5 MDM pump driver
Shelby MAF in 3.5" intake tube
MAFia
Ford racing coil packs
KB Boost-a-spark
Cooling Mist Methanol injection
Hellion twin 61mm turbo kit
Bassani 3" x pipe
Magnaflow 3" straight through mufflers
UPR tubular K member
UPR A arms
UPR 14" 175 front coil springs
Strange 10 way adjustable front struts
Strange 10 way adjustable rear shocks
UPR Caster/Camber plates
UPR bumpsteer kit
Kenny Brown Sub frame connctors
Maximum motorsports adjustable lower control arms
UPR double adjustable upper control arms
GT springs
Welded and reinforced 03 Mach 1 SRA
Detroit True trac differential
Mac diff cover
Hawk HPS brake pads
Enkei RPF-1 rims
M+H 325 x 17" Drag radials
Built 4R75W from BC Automotive, with upgraded Alto Red clutches
3000 stall L/U converter from Circle D
Custom aluminum drive shaft from Shaftmasters
Billet tranny an diff yokes from the driveshaft shop
Hurst pistol grip 1/4 stick
Corbeau CR-1 Seats
Maximum motorsports 6 point roll bar
Speed of sound pillar pods
Cooling mist meth controller
Innovate LC1/XD-16 wideband
Raptor shift light
Autometer column pod
Autometer mechanical boost gauge
Eboost 2 Boost controller
autometer tranny temp gauge
Summit trunk mount batter kit
Lakewood Battery cut off switch
Black powder coated Enkei RPF-1 rims
American muscle tinted Headlights
American Muscle tinted tail lights
JLT Carbon fiber radiator cover
Ford Racing coil covers
Tims Custom powder coated Intake, intake tube, valve covers
35% tinted windows
Powder coated intake tube, valve covers and intake.
Old May 9, 2012 | 02:47 PM
donho's Avatar
donho is infamous around these parts
Nice ride.
The auto should pick it up alot. In your vid, it appeared to still have a stick.
I had a Strictly Performance built 03 Cobra and it was a blast driving it.
GLWS!
Old May 10, 2012 | 06:14 AM
2bscrewed's Avatar
Originally Posted by donho
Nice ride.
GLWS!
Thanks. now that the converter was loosened up a bit, its a night and day difference to how much quicker it is with the auto.
Old May 10, 2012 | 10:45 AM
Divexxtreme's Avatar
Bump for a very honest seller, and solid car. GLWS, Shane.
Old May 10, 2012 | 12:20 PM
Dr_jitsu's Avatar
That is a hell of a lot of performance for $28k
Old May 10, 2012 | 01:53 PM
2bscrewed's Avatar
Thanks Scott.
Thanks, it def cost a lot more to get it there! Making 1000 RWHP in anything, even a Mustang isn't cheap.
Old May 10, 2012 | 03:59 PM
donho's Avatar
Diveeextreee?
Are you the one who came to my Atco Track Rental???
From the M3 board??
If so, whats been going on? Besides killer GTRs??
Old May 10, 2012 | 04:33 PM
Kapoosh1's Avatar
Kapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura about
GLWS, that's one sweet terminator.
Old May 10, 2012 | 06:00 PM
2bscrewed's Avatar
Thanks!
Old May 13, 2012 | 06:29 AM
jester's Avatar
¿Señor Member?
jester has a spectacular aura aboutjester has a spectacular aura about
Sad to see it go, but good luck with the sale, Shane!
Old May 15, 2012 | 07:12 AM
2bscrewed's Avatar
Thanks James
Old May 15, 2012 | 09:04 PM
2bscrewed's Avatar
Sale pending.
Old May 15, 2012 | 09:33 PM
Nice!
Old May 16, 2012 | 06:29 PM
Saleen S7 TT's Avatar
Saleen S7 TT is infamous around these parts
I really wish I had an extra $10K sitting around, then this would be mine in a heartbeat. Sadly, I can only spend $18k and that's pushing it since I want to do straight cash with no loan. GLWS!
the5
Oct 14, 2015 06:46 AM
FUTURESTAR
Sep 23, 2015 05:42 PM
rohnin
Sep 7, 2015 01:10 PM
Sep 3, 2015 04:56 PM
