1989 Toyota MR2 Supercharged
Year: 1989
Make: Toyota
Model: MR2
Price: $5500
Mileage: 162600
Color: Blue
Location (State): MI
Transmission: Manual
Drivetrain: Rear Wheel Drive
VIN: JT2AW16J8K0146182
162,xxx miles
$5,500
Contact: PM / monkeyking631@gmail.com / 248-408-7692
I bought this car on March 25, 2011 with 154,000 miles from New Hampshire and drove it 850 miles back home to Michigan. Since then, I have done a ton of maintenance and some tasteful modifications. I only drive it on nice sunny days and it now has 162,xxx miles.
The previous owner repainted the car. The front fenders were replaced at that time and are perfect. The rear fenders were repaired before painting, and have some imperfections up close. Overall, the exterior looks very clean and gets complimented all the time, but there are some paint imperfections up close. No dents or scrapes anywhere. The interior is in great shape and the seats look brand new.
Oil changed every 2,000 miles with AMSOIL Synthetic 10W-40 Premium Protection oil and AMSOIL filter.
I have records and receipts for everything. I have logged everything I have done since buying this car.
Always garaged during my ownership. Stored in garage over winters with battery tender and AMSOIL gasoline stabilizer.
Engine:
Techno Toy Tuning (TTT) 175mm crank pulley with BMW idler pulley and Bando 5PK980 belt, 159k miles
ABV mod
Grunt Box with indicator light wired to dash, 159k miles
10” SPAL pusher fan mounted on bottom on intercooler and wired with SPAL fan relay harness, 159k miles
HKS Super Mega Flow Intake
Replaced distributor seals, 162k miles
NGK BKR7E spark plugs, 160k miles
Flushed coolant with Toyota Red AntiFreeze, 160k miles
Replaced thermostat, thermostat gasket, and radiator cap with OEM Toyota parts, 160k miles
Replaced timing belt, timing belt idler, and tension spring with OEM Toyota parts, 159k miles
Flushed engine oil with AMSOIL Engine Flush, 159k miles
Replaced front motor mount, 156k miles
Replaced supercharger oil, 155k miles
Clutch:
CRW solid roller clutch clevis with clutch pedal bearing, 159k miles
Techna-Fit stainless steel clutch line, 159k miles
Replaced clutch master cylinder, 159k miles
Replaced clutch slave cylinder, 159k miles
Clutch fluid flushed and bled with ATE Super Blue DOT4 fluid
Clutch was replaced by previous owner and feels great
Exhaust:
20V blacktop header with heat wrapping, 159k miles
20V blacktop downpipe, 159k miles
Custom exhaust with 2.5” pipe welded to 20V blacktop downpipe, ball and socket flex flange, Vibrant Streetpower center inlet polished muffler, dual 2.25” mandrel bent outlets, 159k miles
Exhaust sounds amazing!
EGR deleted (removed EGR pipe, valve, vacuum modulator, and vacuum hoses; capped fittings and installed EGR block-off plate with gasket on intake manifold), 159k miles
Suspension:
Front and Rear Suspension Techniques (ST) sway bars with polyurethane bushings, 158k miles
High & Tight adjustable front end links, 158k miles
Adjustable rear end links, 158k miles
Prothane polyurethane complete bushing set (front and rear control arms, front and rear strut rods, steering rack), 158k miles
Replaced all 4 ball joints and 2 front outer tie rod ends, 159k miles
TRD Stage 1 Alignment, 159k miles
Replaced rear shocks with Koni Yellows
Replaced front shocks with new OEM
Springs a little lower than stock
Interior:
Momo steering wheel
Short shifter
Celica GTS clutch and brake pedal covers
Original T-top shades and storage bags in great condition
Brakes:
Stainless steel brake lines
Slotted and cross drilled rotors
About 50% remaining on front pads, 75% on rear pads
Wheels/Tires:
Enkei RF-1 16x7 wheels
Falken Azenis RT-615K tires, 205/40R16 front, 215/45R16 rear – Awesome tires with at least 50% tread remaining
Extra Parts:
Spare dash in perfect condition
2 sets of spark plugs
Stock air box with filter
All removed EGR parts can be included
Stock exhaust parts can be included
Stock front sway bar and links can be included
All pictures below are from the past few weeks
I have always admired these also and yours looks nice= but could use a quick engine clean glws.
Thanks! Yeah, it shouldn't take much to clean up the engine bay a little... just haven't gotten around to it.
