F/S 2002 Carrara White 996 Turbo
Old Aug 4, 2019 | 08:38 PM
Dr. Jekyll's Avatar
Dr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of light
Year: 2002
Make: Porsche
Model: 911
Price: $0
Mileage: 36991
Color: Carrara White
Location (State): VA
Transmission: Manual
Drivetrain: 4WD & AWD
SOLD
Up for sale is my 2002 Carrara White / Savannah, 6-speed Porsche 911 Turbo. It currently has 36,991 miles on it and runs flawlessly. I’ve owned it since 2011 and have only put about 6k miles on. Always garaged, never tracked, and meticulously maintained. No expense has been spared with this car.
Basic Information
- 2002 Porsche 911 Turbo, 6 speed - Carrara White, Savannah Beige interior.
- 36,991 miles
- Sunroof
- Clean CarFax - No accidents
- Title in hand, no liens
- The car has never been tracked
- The car has always been garaged and religiously washed/detailed.
Modifications
Engine (approximately 650bhp)
- AMS billet K16 turbos with fuel upgrade (72lbs fuel injectors)
- EPL custom ECU tuning, 1.4 bar on 93oct
- OEM Porsche 997GT2RS intercoolers
- Unobtainium Welding 3” exhaust (v-banded mufflers and straight pipes)
- Forge silicone boost hoses (red)
- RSS engine mounts
- Odyssey 925 lightweight battery with Rennline battery hold-down
- Oil changed every year (not enough miles per year to change every 3-5k miles)
- 997 coil packs
- New MAF, MAP, N75 valve, N249 valve, air filter, spark plugs (NGK BKR7E), ignition switch, fuel filter
- All vacuum lines zip-tied and hose clamped. No boost leaks.
Transmission:
- Spec stage 2+ clutch
- 996 GT2 clutch hydraulics
- 997 GT3RS shifter
- 996 Cup shift cables
- G-box detent
- Transmission and differential fluid change 18m ago (Mobile 1 Delvac 75w90)
- Modified OEM transmission mount
- No 2nd gear pop-out issues
- New front passenger wheel bearing, inner CV joint, and inner/outer CV boots
Suspension/Brakes
- JIC ZMS-S single adjustable suspension w/ 8kg/12kg springs (~2k miles on them)
- H&R front and rear sway bars
- Rennline adjustable rear toe links with toe locking plates
- Tarett Engineering rear sway bar end links
- RSS rear caster pucks
- TRG front sway bar end links
- New OEM inner/outer front tie rod ends
- Braided steel brake lines
- Plenty of pad/rotor life left on front and rear brakes
- Corner balanced and aligned
Wheels
- BBS Motorsports E88 18x9 front / 18x12 rear. Custom painted matte black centers, gloss black lips. Rebuilt with new hardware by Supreme Power in CA (less than 100 miles since the rebuild)
- Toyo R888 tires 235/40r18 front / 315/30r18 rear (plenty of life left on both)
Interior
- OEM European 996 GT3 seats in savannah beige
- FVD steering wheel in savannah beige
- Porsche Tequipment roll bar
- Porsche Tequipment leather shift **** and e-brake
- GT3 center console delete kit
- Alpine head unit
- Turbo timer
- Custom Lloyd floor mats
- LED interior lights
Exterior
- Genuine Techart Type II rear wing
- Porsche Aero front splitter
- Silver front Porsche badge
- Rear wiper delete
- Osram Xenarc 6000k headlight bulbs
- Full detail and ceramic coating (CQuartz UK 3.0) 4m ago
Stock parts included in sale:
- Spare tire and tools
- Rear seats and hardware
- Bose sub box
- Stock clutch hydraulics
- Stock shifter cables
- Stock exhaust (gutted cats)
- Rear wiper arm and motors
- Center console parts from GT3 console delete
Pictures
Old Aug 5, 2019 | 12:04 AM
needforspeed502's Avatar
needforspeed502 is a splendid one to beholdneedforspeed502 is a splendid one to beholdneedforspeed502 is a splendid one to beholdneedforspeed502 is a splendid one to beholdneedforspeed502 is a splendid one to beholdneedforspeed502 is a splendid one to beholdneedforspeed502 is a splendid one to beholdneedforspeed502 is a splendid one to behold
Cant tell from pictures, does it have a sunroof?
Old Aug 5, 2019 | 04:25 AM
Dr. Jekyll's Avatar
Yes, it does have a sunroof. I edited the original ad to include that information. Thanks!
Old Aug 5, 2019 | 02:08 PM
Jferrante's Avatar
Jferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant future
What a car! I am in Arlington if anyone wants me to look at it for them
Old Aug 5, 2019 | 05:34 PM
Dr. Jekyll's Avatar
Thanks! I’m in Alexandria, so just right down the road from you (or 2 hours with traffic ).
Old Aug 7, 2019 | 09:28 PM
dak125's Avatar
dak125 is infamous around these parts
Gorgeous car, glws!
Old Aug 9, 2019 | 10:33 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Digging that interior
Old Aug 9, 2019 | 03:31 PM
Kendall993's Avatar
Kendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to behold
I can only hope that when Im done with my house remodel that a similar car is available for me to pick up. Amazing build!! Someone is going to have a lot of fun with this!!
Old Aug 9, 2019 | 09:09 PM
Civicbeater's Avatar
Civicbeater is infamous around these parts
gorgeous!
Old Aug 10, 2019 | 05:16 AM
arjayr33's Avatar
arjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond repute
Bumpity for ya! can't believed no one grabbed this one yet
Old Aug 10, 2019 | 07:14 AM
Myclue's Avatar
Myclue is a jewel in the roughMyclue is a jewel in the roughMyclue is a jewel in the roughMyclue is a jewel in the rough
such a pretty 996. Glws
Old Aug 11, 2019 | 11:43 AM
Dr. Jekyll's Avatar
Just re-adjust your priorities. You can re-do a kitchen anytime but a white 996tt only comes up for sale once in a blue moon!
Old Aug 11, 2019 | 05:09 PM
Kendall993's Avatar
Lol.... you do make a good point. My better half would have a different opinion and fortunately for me I get to wake up to her every day. GLWS
Old Aug 18, 2019 | 12:04 PM
Dr. Jekyll's Avatar
Bump
Old Aug 29, 2019 | 05:17 PM
Dr. Jekyll's Avatar
I took a few new pictures this past weekend:
