2002 Shifter kart
Old Nov 4, 2006 | 09:36 AM
E36M's Avatar
E36M is infamous around these parts
2002 Shifter kart
2002 GP5 CR125cc shifter kart
Has a 99 CR125 motor that was done by Mike Bellew, the top end was redone to be reliable by Carlson Bogan.
new 50mm axle, new RLV silencer, new T3 pipe (10 races), exhaust manifold with o-rings, programmable Vortex ignition, Vforce3 reed assembly with reeds in excellent shape, C&R radiator, new piston, ring, wrist pin, Modified Kehein carb with dual fuel pumps for pump around, and a new Tillett seat.
Frame, in great condition, this frame was just looked over for 7 hours by 2 guys at a local shop. It is perfectly straight, no cracks.
Spares
Numerous used front and rear brakes pads
Numerous brake shims
6 clutch friction discs and floaters
1 17 tooth driver gear
1 23 tooth sprocket
3 sidepods
3 noses
1 floorpan
1 NEW clutch cable
1 NEW coil
2 carb needles(CCJ, CGJ)
4 pilot jets(48, 50, 52, 55)
9 main jets(155, 158, 162, 165, 168, 170, 172, 175, 178)
1 exhaust manifold
1 intake manifold
1 RS piston, ring, wrist pin and bearing (6 races)
1 NEW cylinder gasket
1 intake manifold gasket
2sets of used Bridgestone YHC tires
1 set used MG Green tires
1 steering rod with steering wheel and clutch lever
5 front spindles
2 front brake rotors and hubs
2 steering connecting rods
1 rear brake rotor and brake hub for 50mm axle
1 rear brake rotor and brake hub for 40mm axle
Extra brake caliper hardware
2 used Vforce 3 reeds
(AIM gold, and weights showen in pictures are not included)
Must sell, going away to college. 3,999 obo.
Old Nov 4, 2006 | 10:17 AM
MgnFicnT's Avatar
MgnFicnT is infamous around these parts
nice little toy
Old Nov 4, 2006 | 03:07 PM
comptechgsr's Avatar
comptechgsr is infamous around these parts
where is this located, and how long till next rebuild?
my buddy is looking for a used stock moto
Old Nov 4, 2006 | 06:10 PM
E36M's Avatar
It's located in Ohio. But this probably isn't a good one for stock moto, depends on the rules in your area. This motor has been done from top to bottom. My motor builder said to change the ring in about 20 hours, it has 3 on it now. Then rebuild the top end about 20 hours after that. According to him it's good to go for a pretty long time.
Old Nov 4, 2006 | 06:27 PM
yeah we have a modified ICC moto class that runs with stock icc...
my friends lookin to get into stock moto.
regardless , good luck!
Old Nov 4, 2006 | 07:36 PM
skibum's Avatar
skibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud of
Oh man that is sick. I just bought a Rotax a few months ago and wish this deal would have been around then.
Smokin deal - someone needs to pick this up asap!
Old Nov 5, 2006 | 08:16 PM
Origyns 973's Avatar
Origyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to behold
Now heres my question, wheres the clutch?
Old Nov 6, 2006 | 10:49 AM
E36M's Avatar
The clutch is behind the steering wheel.
Old Nov 6, 2006 | 10:58 AM
Been tryin to figure that out for a while
Old Nov 6, 2006 | 11:10 AM
E36M's Avatar
it's alright, btw it has a new steering wheel on it
Glasgo
Nov 30, 2015 02:37 PM
vogz
Oct 12, 2015 08:46 AM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
