A3076 vs. A28 vs. K16G vs. K24 Dyno Overlay
#211
#212
Dr. Evil, I had some suspicions up till this point but after reading this post........
1. How old are you?
2. Is your Porsche a full scale Porsche or a 1/24 scale?
3. Are you a "real" Evil Doctor or did you get your evil medical
license from an unaccredited internet source. Maybe Evlimd.com?
1. How old are you?
#213
Forget it dude.. you don't get it and you never will. You don't read very well. I said a piston and sleeve like you bought is a "bolt on" TO ME, NOT the general population. I don't pay people to turn wrenches so everything is a bolt on TO ME.
Regarding the tuning, keep talking in circles. First you say that all the tuners in the world out tune Porsche, then you stated that you never said you can tune better than Porsche.. Let me help you out, you better hope you can tune better than Porsche or you will have a very difficult car to drive my friend. That is of course if you can keep it together.
[B]
Changing the fuel type/delivery is the epitome of influencing volumetric efficiency.
Oxygen is only one component of VE. The rate and percentage of thermal energy
( fuel) converted to mechanical energy is integral to the VE.
[/B]
This is news to me. Can you explain this further? Please explain how this happens.
Also, me being defensive? why? this is the internet, I can care less what you do. I don't even know you BUT I sure know VE and it is NOT what you describe.
[B]
[/B]
Volumetric efficiency is affected by the following fuel, engine design, and engine operating variables:
1.Fuel type, fuel/air ratio, fraction of fuel vaporized in the intake system, and fuel heat of vaporization
2.Mixture temperature uninfluenced by heat transfer
3. Ratio of exhaust to inlet manifold pressures
4. Compression ratio
5. Engine speed
6. Intake and exhaust manifold end port design
7. Intake and exhaust valve geometry, size, lift, and timings
http://howautowork.com/part_1/ch_2/V...ciency_10.html
#214
Dr. Evil is reportedly color blind. Legend has it, he was fishing for piranha
in the Guyana's and a local voodoo shaman gave him an ancient curse
that left him color blind and devoid of logic.
The pink text is an inside slight relative to the aforementioned story.
I can't speak to the accuracy of the story but then again, he made no
mention of the pink text and he is quite clearly completely illogical.
so.... 71/73's are the *new* hybrids, huh? why do i think my car will already pull 0-100 in 6 seconds. must be a time zone internet thing
#215
That's the power band of those little turbos. Probably not a much
better turbo setup in the world for what you do.
If you were gettin all competitive on the track, maybe the a28s.
I got a 5.8 0-100 with the alpha28s and literally a half second of
that was wheel spin shifting 2nd to 3rd.
#216
that's better, man. whew. i was gonna buy ya a drink, but then we'd all be worryin about ya LOL. truth be told. all this straight line trap talk ( and vids ) is making me wish i could run against...
chevy nova's !? w t F!? lol. all good
ps.. 6 sec's uphill, i meant HA
#217
http://websters-online-dictionary.or...ency#Wikipedia
Volumetric efficiency in internal combustion engine design refers to the efficiency with which the engine can move the charge into and out of the cylinders. More correctly, volumetric efficiency is a ratio (or percentage) of what volume of fuel and air actually enters the cylinder during induction to the actual capacity of the cylinder under static conditions. Therefore, those engines that can create higher induction manifold pressures - above ambient - will have efficiencies greater than 100%. Volumetric efficiencies can be improved in a number of ways, but most notably the size of the valve openings compared to the volume of the cylinder and streamlining the ports. Engines with higher volumetric efficiency will generally be able to run at higher RPM and produce more overall power due to less parasitic power loss moving air in and out of the engine.
There are several standard ways to improve volumetric efficiency. A common approach for manufacturers is to use a larger valves or multiple valves. Larger valves increase flow but weigh more. Multi-valve engines combine two or more smaller valves with areas greater than a single, large valve while having less weight. Carefully streamlining the ports increases flow capability. This is referred to as Porting and is done with the aid of an air flow bench for testing.
Today, automobile engines typically have four valves per cylinder. Many high performance cars in the 1970s used carefully arranged air intakes and "tuned" exhaust systems to "push" air into and out of the cylinders, making use of the resonance of the system. Two-stroke engines take this concept even further with expansion chambers that returns the escaping air-fuel mixture back to the cylinder. A more modern technique, variable valve timing, attempts to address changes in volumetric efficiency with changes in RPM of the engine: at higher RPM the engine needs the valves open for a greater percentage of the cycle time to move the charge in and out of the engine.
Volumetric efficiencies above 100% can be reached by using forced induction such as supercharging or turbocharging.
More "radical" solutions include the sleeve valve design, in which the valves are replaced outright with a rotating sleeve around the piston, or alternately a rotating sleeve under the cylinder head. In this system the ports can be as large as necessary, up to that of the entire cylinder wall. However there is a practical upper limit due to the strength of the sleeve, at larger sizes the pressure inside the cylinder can "pop" the sleeve if the port is too large.
Volumetric Efficiency is frequently abbreviated as "VE" when discussing engine efficiency.
I suggest you(or anyone) read a copy of Sir Harry Ricardo's book on high speed internal combustion engines..
#218
New build sounds promising.
Any reason why your not going for a bigger turbo?
As everything is getting built, it just seems a waste to not utilize the built block for a bigger turbo.
Spool wise you can negate lag with anti lag and driving stye anyhow.
Depends what records your going after though I guess?...
3076s on the dyno and 3076s on the street are 2 different things.
The 3073s offer plenty of power ( 780-830 whp ) and my car will
be very light. We are also addressing the gearing.
Our goal is a well rounded daily driver. We're trying to achieve balance.
I don't want a monster horsepower setup that's relegated to interstate
pulls. There's nothing wrong with that if that's what you want.
And yep, lag will be minimal.
#219
what about lsd? ( not yer freakin mushrooms again lol ) and taller gears.. 1st? what else are you doing? better keep the triple cone synchros or re-learn double clutching
#220
Sir Harry Ricardo is a known horse thief and traveling charlatan.
He sold my brother in law a trunk full of " Sir Harry's Gout tonic and
and impotence elixir." Needless to say, my brother in law still suffers
the gout and to this day he's tryin to shoot pool with a rope.
I find it very suspect that Sir Harry Ricardo is now involved in the
motorcar industry.
I personally don't trust him or his brother Ricky.
#221
We're consulting with some gents in the know.
#222
I just ran across the photo of Sir Harry Ricardo.....
with his trademark handlebar mustache on his forehead.
and his ne'er do well brother, Ricky.
Jeez, has this guy ever made an honest dollar in his life?
#223
60/40 lsd gotta have it. steel gears 3/5? lol. yeah. enquiring minds wanna know
#224
All this talk of how these 3073s are such a great new find..
WOW,, Hard to believe that not any tuners have brought them to light or any one for that matter to prove they work better then 3071s on the street.. Lol..
#225
There's an infinite choice of gearing. We wanna
nail it the first time. The 04 - 05 gt3 trans (G96)
would be perfect plug and play for your setup.
Not so much for 800+ hp.
You have to do rwd conversion on the gt3 trans.
We're gathering info on what would work best
relative to estimated power levels.
